View Poll Results: Is catch can working?
YES..Accumulation in the can
42.86%
Yes..Accumulation elsewhere (hoses)
28.57%
NO..Not working
28.57%
Voters: 14. You may not vote on this poll
Catch can POLL for LNFS
Anyone catching stuff in their's?
I have read several posts where nothing is being caught in the can, but residue on pipes and sensors has still been eliminated! Some have speculated that the vapors are being condensed in the tubes..especially LONGER TUBES of MPX set up.
So I have 3 options for accumulation. Basically: (1) in the can...(2)Somewhere (hoses?)...3) No Accumulation at all..not working.
PLEASE NOTE!!
THIS IS FOR TC CARS ONLY. ANYONE MAY MAY POST, BUT ONLY TC'S MAY VOTE ON THIS!
PLEASE NOTE!!
Thing is, you're not not be seeing the vapor deposits that are burned onto the back of the intake valves
None in the IC, lower cp or on any sensors as I had all that apart when it went stock for the sale.
Oh, I saw those when I had the intake mani off, it wasn't from the intake piping though. I used zero oil every 5k miles. I scrubbed them off the stems with solvent and a stiff brush. The buildup on the valve stems is from blowback from the cylinders. Even those with catchcans have that on a DI engine as the intake valves never see any raw fuel to clean them, but you know that already.
From Perrin web site..lots of info here too:
Perrin Performance - Oil Catch Can / Overflow Tank
Blow by mentioned....
Why do I need an Oil Catch Can?
Lets look at your engine for a moment. Every engine during the normal combustion process, has blow-by. Engine Blow-by is excess combustion gases that leak by the piston rings and escape into the engine crankcase. During each compression or power stroke of a normal engine cycle, a very small amount of gases leak by the piston rings. This happens because the piston rings do not create a perfect seal. This Blow-by of gases is very small, but the higher the RPM and the more pistons, the more the blow-by starts to create pressure in the crank.
This pressure needs to be released, and is done so by crank case vents. Because manufactures have to keep environmental issues in mind, these gases can’t just be vented to atmosphere. So the OEM’s vent these gases back to the intake system to be re-burned. This all sounds good, but Blow by is nasty stuff!
Engine blow-by contains gases and oil from the crankcase. The gases aren’t really a problem, but the oil is. This oily mess coats everything in its path as it makes it way back to the combustion chamber. This nasty oil mess gets into the turbo, then boost tubes,then intercooler, into the intake manifold, and finally back into the engine. As the oil creeps in between couplers and boost tubes, it can cause the connection pop off under boost. This oil then gets into the intercooler, coating all the cooling fins. This greatly effects the ability of the intercooler to cool, and the efficiency of it will drop! This will cause a huge loss in power and can cause detonation. The last place this oily mess sees before the combustion chamber is the intake valves. Because of the temp differences and the oil impacting them, the oil will start to build up and form sludge. This adds up over time, and can cause many other problems, and hurt performance.
From this you can see, blow-by is bad, and it needs to be dealt with
No, just crankcase blowby does. Positive Crankcase Ventilation.
Exhaust valve leakage goes out... the exhaust, intake blow back ends up in the intake mani and sucked in to the next valve that opens...or deposits on the stem, ect. Intake valve leakage, turbulence from the intake/exhaust valve overlap & resulting scavaging, or lack of it, all come into play with the intake stem deposits. If you are getting it from turbo seal leaks, the Upper CP & IC would be loaded. If the rings have a good seal the PCV won't see much.
A catch can is a good idea if you need one. I just didn't.
Thanks for feedback.
i had some oil on my MAP sensor that caused reduced boost pressure and my car ran like crap.
i was wondering if it was PCV oil or the valve blow back. im making my catch can just in case.
EDITED:
Sorry..I see you have a TC..I wasn't looking at your SIG!
Where do you put the hose for a catch can? I really don't know anything about them or how they work. I wonder if thats why i get a lil smoke out the exhaust sometimes when i'm in boost?
Here's a hint:
Two from can go here..to Turbo outlet and Valve cover outlet:
Here's MPX can and hoses going to it (from locations shown above) with stock air box set up:
patooyee
Oct 1, 2015 01:07 PM
