Scraping sound....help?
I am having a scraping sound, It started after I installed a new clutch, flywheel and I used ARP flywheel bolts from zzp. Both the clutch and flywheel are clutch masters. I never broken in a clutch before so I am unsure if it is normal? the scraping matches the RPM's but after high enough rpm's I can't hear it over the engine/exhaust noise. It's not to loud but its very noticeable any idea's to give me some piece of mind that I didn't mess up something.
I might of solved my own issue but I read that it could be the throw out bearing, I'm thinking if it is while I was cleaning the bell housing i got dirt in it? or it's just going out.
I tried cleaning it and still does the same ****...I'm done with this car it's a lemon so many things I have fixed and it only has 20k miles on it
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
