Changing Pistons....
Old Jan 22, 2010 | 04:42 AM
cardelino18's Avatar
ok so for those of you that have changed your own pistons,
from 1-10, 1 being the easiest, how hard is it to install them?
any special tools?
any suggestions?
Spec of the torque need for the bolts?
my buddy works at HONDA and he is going to do it for me but he need all the information since its not a honda....
some can help me out please?
Bump?!?
Last edited by cardelino18; Jan 22, 2010 at 04:42 AM. Reason: Automerged Doublepost
Old Jan 22, 2010 | 04:47 AM
Southtown57's Avatar
I would wait for Maven to chime in. Probably not that bad for a mechanic to do, but someone that has never torn apart an engine, now that's a different story.
Anyways bump for you till someone can answer...
Old Jan 22, 2010 | 04:55 AM
Thanks!
Old Jan 22, 2010 | 08:30 AM
Leveecius's Avatar
Well, changing pistons is really not all that hard if you've done it before. As for someone that hasn't done it before, it's not too terribly difficult. I have found the easiest way to do them is from the bottom of the car. I usually take out all the plugs, drain the oil, drop the oil pan, and from there I can unbolt the connecting rods from the crank and by spinning the motor by hand I can remove the pistons 1 by 1 and re-insert them the same way (this way you don't have to take off the timing chain and screw your timing up). Now, there WILL be a special tool you are going to need to get the pistons back in, and that is the piston ring compressor (make sure your piston rings are offset before compressing them this way you won't have blow-by), compress the rings put the tool to the cylinder and push the piston into the cylinder (you can tap lightly on them with a soft-face deadblow hammer if you can't push them in completely). Align the crank with the rods and connect the connecting rod end cap/bearings (Make sure to TORQUE them down to spec, and put the bearings on the right way (as they will scorch your crank and blow your bearings if they aren't)). After all that, put pan back on, fill with oil, start it up and let it run for about 10 minutes at an idle at about 1500-2000 RPMS to set the rings. Then you are good!
If I missed anything or someone has a better way, please chime in.
Old Jan 22, 2010 | 08:43 AM
06blackg85ss's Avatar
really should take the motor out, with it in the car it is a bit of a bitch to line up the timing chain correctly.
and all the tq specs and ring gap specs are on www.gmtunersource.com plus the install intructions you can print out and give to your freind.
if you have to ask, you shouldn't really try it yourself, especially on a brand new car.
Old Jan 22, 2010 | 12:28 PM
09CobaltSS1's Avatar
soo I may be wrong (coming from a primarily V8 backround and all) but it is just about impossible to clear the pistons of the crank when attempting to remove them from the bottom. You will most dfinitely need to remove the mains and crank in order to remove pistons from the oil pan. Not to mention, it will be even more difficult to clear the crank with a ring compressor strapped to the piston, and I'd also be pretty nervous about tapping in those pistons from the bottom without a skirt guiding my down the cylinder like you would going in from the top.
Maybe I speak for myself here, but I'm pretty awestricken with how "easy" people seem to make this process out to be. It really not that cut and dry, and unless you expect your car to ever run propperly again, I would highly recommend bringing it to a professional engine builder.
Just my oppinion....
Old Jan 22, 2010 | 12:34 PM
go to the link I posted.... the build book is on there.
and you have to pull the head and pop the pistons out the top
Old Jan 22, 2010 | 01:40 PM
can you give me a direct link because i cant find it
Old Jan 22, 2010 | 01:56 PM
DAMN people are goddamn lazy these days
http://www.gmtunersource.com/index.p...lsj-build-book
Old Jan 22, 2010 | 04:31 PM
Boosted_Cobalt09's Avatar
^^^^true that. not to step on toes here but find someone thats worked on these cars before.
Old Jan 22, 2010 | 06:51 PM
Maven's Avatar
On your 1-10 scale, this is a 9 on the engine scale.
Youre not gonna get the pistons out the bottom of the engine. You need to remove the head. You dont need to remove the engine
You need torque wrench, a way to accurately measure bolt angle if you use stock type headbolts and rod bolts, piston ring compressor.
You should just by the service manual. If youre putting pistons in this soon then a manual set will be the best $135 you ever spend on this car.
Old Jan 23, 2010 | 01:07 PM
Stamina's Avatar
When they replaced my piston, they kept the crank in place, disconnected the rod from the crank, took off the head, and took out and put in the piston through the top. They kept the engine in the car.
Old Jan 23, 2010 | 01:11 PM
Maven's Avatar
Yup, thats how its done in the car
Old Jan 23, 2010 | 01:12 PM
Stamina's Avatar
How much mileage on the engine until you have to start worrying about the cylinder tapering towards the top?
Old Jan 23, 2010 | 01:17 PM
Terminator2's Avatar
That sounds like how you would get it done without removing the engine from the car.
Old Jan 23, 2010 | 01:19 PM
Maven's Avatar
really hard to put a mileage on it. best to measure.
Old Jan 23, 2010 | 01:21 PM
Stamina's Avatar
Okay cool, just wondered. I don't think the dealer measured, and I've got 30k+ miles on mine now, so it got me worried about the rings on that cylinder again.
Old Jan 25, 2010 | 11:32 PM
Nightmare9's Avatar
I'm kind of wondering how on earth are you going to hone the cylinder walls to get the new rings to seal if you don't clear the cylinders (or your gonna get TONS of filings everywhere and just destroy the engine).
Also... WHY are you replacing the pistons?
Old Jan 25, 2010 | 11:49 PM
i think i cracked one...
Old Jan 26, 2010 | 01:09 AM
Kozy's Avatar
i really suggest taking the engine out.. just like im sure most people would. not only is it more difficult to to with the motor in the car.. when your working with something this important to your car running you dont want to be all crammed under your car with limited visibility... plus you said you think you cracked one?
id definitely take the engine out if not because its safer, because you dont know exactly what the problem is.. i have a story i could go into.. https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/cracked-piston-1-a-198277/ ... i posted in this thread about it.
also youre going to need a hone tool idk if anyone had mentioned that.
Old Jan 26, 2010 | 08:46 AM
Would not suprise me at all. You need to do a leak down test to determine if all cylinders have the proper amount of compression. Should be approx 9.4 CR X 14.5 psi atm = 136.3psi.
Old Jan 26, 2010 | 04:10 PM
Kozy's Avatar
definitely a good idea ^ thanks for posting those numbers up there too
Old Jan 26, 2010 | 09:04 PM
Maven's Avatar
Its honestly no harder in the car(assuming you have a lift)
And as far as compression i would honestly hope to see more than 135psi, you have to remember a compression test is a dynamic thing, we have air moving, its not just A*B=C.
For example a healthy LSJ with its 9.5:1 compression ration will easily hit 210psi on a compresion check.
I would say 100-125 is a safe MINIMUM pressure to see. As always the variances from cylinder to cylinder are very important.
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
