check engine light???
i noticed two days ago my check engine light came yet i feel no difference. wut could it be? i asked onstar like 8 times and they couldnt find anything, also took it to autozone and couldnt pick up anything either yet the dam light is still on. any suggestions before i take it to da stealership?
get a reader.......my friend had the same thing happen........turned out his stage 2 tune wasnt tunned right and he was running lean and there was no noticeable difference in his car........o ya and tighten all your caps (gas, oil, radiator, etc.) just to make sure
Look i work at a chevy dealer. your car is most certainly under warranty, take it to the dealer. i woudl not recommend anyone to goto autozone, advanced ect for diag. they are a parts store, not a service center. we get people with problems , that went to autozone .autozone ect clears the code , and when they come into the dealer it makes it hard for us ot diag the problem. on another note to who ever had problem wiht the gas cap. there is no code for the gas cap its evap large or small leak. a gas cap is just a quick thing to check if you get an evap problem leak code. also make sure it is the cel. if its the tire light and somethign for everyone to keep in mind, the weather is changing, getting colder, and on a real cool mornign the air pressure in yor tires may go below 30 and set the light. so to eliminate the inconvience of the light I recomend running your tires @ 32psi
