check engine light???
Old Nov 11, 2008 | 01:27 PM
08blackbolt's Avatar
i noticed two days ago my check engine light came yet i feel no difference. wut could it be? i asked onstar like 8 times and they couldnt find anything, also took it to autozone and couldnt pick up anything either yet the dam light is still on. any suggestions before i take it to da stealership?
Old Nov 11, 2008 | 01:32 PM
Brenticus's Avatar
sometimes they'll come on if the gas cap isn't sealed properly.
Old Nov 11, 2008 | 01:34 PM
D4u2s0t's Avatar
get the code scanned, that's it. no one can help you without the code.
Old Nov 11, 2008 | 01:40 PM
Tank07's Avatar
get a reader.......my friend had the same thing happen........turned out his stage 2 tune wasnt tunned right and he was running lean and there was no noticeable difference in his car........o ya and tighten all your caps (gas, oil, radiator, etc.) just to make sure
Old Nov 11, 2008 | 02:02 PM
krispy's Avatar
hit the onstar button and have them tell you what it is
Old Nov 12, 2008 | 08:29 AM
i already hit the onstar button n no codes came up same thing with the scanner no codes came up.
Old Nov 12, 2008 | 08:33 AM
Bigmacss/sc's Avatar
if the gas cap is off it will tell you, ive been going throught that the past two weeks and the cap is tight
Old Nov 12, 2008 | 08:40 AM
umrdyldo's Avatar
I had that message for the first time the other day. Hasn't come back yet. I figure it was cold weather problem.
Old Nov 12, 2008 | 01:54 PM
krispy's Avatar
wait, are you sure its not the low tire pressure light?
Old Nov 12, 2008 | 01:55 PM
brickerenator's Avatar
Check your fuses
Old Nov 12, 2008 | 05:15 PM
R4race's Avatar
if the CEL is on and no codes, that sounds like wacky problem. wacky like ECM or cluster malfunction
if the problem is in the cluster and onstar and autozone don't scan it you won't know
Old Nov 12, 2008 | 09:36 PM
Adrenalin9150's Avatar
Look i work at a chevy dealer. your car is most certainly under warranty, take it to the dealer. i woudl not recommend anyone to goto autozone, advanced ect for diag. they are a parts store, not a service center. we get people with problems , that went to autozone .autozone ect clears the code , and when they come into the dealer it makes it hard for us ot diag the problem. on another note to who ever had problem wiht the gas cap. there is no code for the gas cap its evap large or small leak. a gas cap is just a quick thing to check if you get an evap problem leak code. also make sure it is the cel. if its the tire light and somethign for everyone to keep in mind, the weather is changing, getting colder, and on a real cool mornign the air pressure in yor tires may go below 30 and set the light. so to eliminate the inconvience of the light I recomend running your tires @ 32psi
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
