Clear Image Automotive dyno testing, flow bench testing and more...
Old Jan 20, 2009 | 02:36 PM
  #376
40rty's Avatar
I wanna race your Honda dude^^^ wat ya pushin in dat ting?
Old Jan 20, 2009 | 03:22 PM
  #377
Terminator2's Avatar
Originally Posted by Cobaltss/TC
No what we had to do was change the way the boost is applied for now cause of the clutch, once i get the clutch we can go back and pull way more out of her, i just didn't want to break anything
So you are seeing 18 psi or so down low and then ramping it up to 21-22 up high to help with the clutch slip. I dont know what it is about these clutches slipping, mine has never slipped once on the dyno or on the street, but it helps if you wait until at least 3K rpm to go WOT and don't got WOT in 5th while cruising. That seems to be when most have experienced clutch slip.
Old Jan 20, 2009 | 03:52 PM
  #378
Cobaltss/TC's Avatar
That is correct, yeah the only time i see it is in 4th or 5th.
Old Jan 20, 2009 | 04:01 PM
  #379
krispy's Avatar
Any news about recommended O2 simulator w/ catless downpipe? Reason I would need it is that my plan is getting GM stage tune (I want to retain warranty) which would still leave me with a need to eliminate the CEL that would event.
Old Jan 20, 2009 | 04:27 PM
  #380
Does it slip when redline 3rd then shift to 4th or just at lower rpms? Damn rediculous low end torque the stock turbo is capable of
BTW: I bet you love how powerful your car feels now. Over 300whp in a sub 3000lb car is great fun on the street except that WOT in 1st gear induces rediculous amounts of tire spin now for sure.
Old Jan 20, 2009 | 06:20 PM
  #381
ClearImageAuto Dan's Avatar
I'm not going topost pictures until we can build a production down-pipe. Waiting for flanges right now. Is a picture what is stopping you from ordering?
Waiting to hear back about the O2 simms.
I'm set up as a dealer for Spec now so the clutch will be available very shortly as an option when ordering.
Old Jan 20, 2009 | 07:19 PM
  #382
No, no slip at all in 3rd or 4th at redline it is usually at 3500 rpm range. Yeah it is fun for sure i soldom ever use 1st just to get to 20mph then dump to 2nd gear then floor it get NICE wheel spin but no torque steer and i mean within 3-4 seconds later i am already at 60-65 it ******* moves
Old Jan 20, 2009 | 09:03 PM
  #383
yobrigidey's Avatar
No, no slip at all in 3rd or 4th at redline it is usually at 3500 rpm range. Yeah it is fun for sure i soldom ever use 1st just to get to 20mph then dump to 2nd gear then floor it get NICE wheel spin but no torque steer and i mean within 2-3 seconds later i am already at 60-65 it ******* moves
yeah...about that.....I'ma need to see some vids.
Old Jan 20, 2009 | 09:07 PM
  #384
Yeah kinda hard to make videos when you are the only one in the car. Going to the track this spring
Old Jan 20, 2009 | 10:45 PM
  #385
08blackbolt's Avatar
wut time u think u'll get?
Old Jan 20, 2009 | 10:48 PM
  #386
kling1022's Avatar
as long as they use better tires they will have 12's easy. probably mid 12's
  #387
Yup tires are my big flaw right now can't grab traction through 2nd
Old Jan 20, 2009 | 10:50 PM
  #388
kling1022's Avatar
yep I know what you mean. I think i might get nt01's they are sweet
Old Jan 20, 2009 | 10:54 PM
  #389
do you have the link to where i can purchase this tune?
Old Jan 20, 2009 | 10:57 PM
  #390
Mazdaboi318's Avatar
https://www.trifectaperformance.com/cia-order
is that what you are looking for?
Old Jan 20, 2009 | 10:59 PM
  #391
kling1022's Avatar
AHHH you beat me to it. lol nice job
Old Jan 21, 2009 | 12:17 PM
  #392
blackrocky's Avatar
did you get the tune yet?
im gettin mines this sat.
Old Jan 21, 2009 | 03:58 PM
  #393
So yeah SPEC clutch forgot to put some info on their website, same with Turbo Tech, but if you are going to get any clutch from SPEC for the LNF motor you need to also buy the flywheel, which puts that over 1000 dollars, so me putting the clutch in ins't going to happen for a couple months
Old Jan 21, 2009 | 04:05 PM
  #394
That sucks why the hell cant we use our existing flywheel it not like it is worn out or anything? I was going to get a spec stage 3+ clutch eventually, but that is like $1300 not including labor.
Old Jan 21, 2009 | 04:30 PM
  #395
Yeah pretty stupid, i have no idea why maybe someone else knows?
Old Jan 21, 2009 | 05:30 PM
  #396
Cyrusthevirus's Avatar
Is the downpipe goin to look like this with this kind of cat possiblity.
dp is stainless by the way
Old Jan 21, 2009 | 05:48 PM
  #397
sheldon729's Avatar
whos DP os that?
Old Jan 21, 2009 | 06:03 PM
  #398
EvilleCobalt's Avatar
Originally Posted by sheldon729
whos DP os that?
X2 looks good.
Old Jan 21, 2009 | 07:01 PM
  #399
MaxVQ35DE's Avatar
flex pipe = fail
  #400
marcusicp's Avatar
Originally Posted by MaxVQ35DE
flex pipe = fail
You sir, are an idiot.
