clutch issues
Old Feb 2, 2010 | 01:55 PM
fosterSS's Avatar
clutch issues
I bought the clutchmasters stage 4 . 4 puck a month ago the dealer put it in for me. The other dayi went to go into first gear and I wouldn't go and there is a weird noise coming in from the slave cylinder it sounds like, anyone know what the problem would be?
Old Feb 2, 2010 | 01:57 PM
Terminator2's Avatar
Throwout bearing is gone or the slave cylinder itself. How is the fluid level?
Old Feb 2, 2010 | 02:01 PM
fosterSS's Avatar
clutch
The fluid is full that was the first thing I checked. I bled the system thinking it was air but it didn't help at all.
Old Feb 2, 2010 | 02:55 PM
Does the clutch pedal just go to the floor with no tension at all? If so and you already bled the system properly with a vacuum bleeder than it is probably the slave. If the clutch pedal feels normal but grinds and makes noises when trying to put it into gear it is most likely the throwout bearing.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
