clutch issues...suggestions?
So I went to turn my car on today (2010) and the clutch just stayed on the floor. I had to physiccally pull it back up. I had to do this a few times then what I did was pump it by hand a few times and it started working again. I would immagine this is some sort of hydraulic issue but has anyone else experienced this problem? Thanks.
**** I dont want that to happen at the track so I am definitely going to bring it in. Also an addendum to that is that hydraulic fluid shared by the brake system as well? The only reason i ask is because ever since my last track event the brakes have felt very mushy. Could it just be that I bould some fluid and now there is air in the lines?
Owch...
I had a problem slightly like this. No matter how far I pushed my clutch in the car still acted as if it wasn't pushed down far enough to go into gear. After I pumped it a few times it would go back to normal, but within driving it would go to acting up again. Take it in the shop... That Warranty goes a long way in situations like this.
