clutch issues...suggestions?
Old Oct 5, 2010 | 08:49 AM
GeauxSS's Avatar
So I went to turn my car on today (2010) and the clutch just stayed on the floor. I had to physiccally pull it back up. I had to do this a few times then what I did was pump it by hand a few times and it started working again. I would immagine this is some sort of hydraulic issue but has anyone else experienced this problem? Thanks.
Old Oct 5, 2010 | 10:05 AM
yamaha288's Avatar
thats kinda scary I would take it in and have it checked out
Did it kinda squeak before?
Old Oct 5, 2010 | 11:57 AM
Grishbok's Avatar
take it in, theyll fix it, definately a hydraulic issue. The vettes are notorious for it.
Old Oct 5, 2010 | 04:24 PM
rukkee's Avatar
My fathers C6 did the same thing at the track ....bad slave cylinder
Old Oct 5, 2010 | 09:12 PM
GeauxSS's Avatar
**** I dont want that to happen at the track so I am definitely going to bring it in. Also an addendum to that is that hydraulic fluid shared by the brake system as well? The only reason i ask is because ever since my last track event the brakes have felt very mushy. Could it just be that I bould some fluid and now there is air in the lines?
Old Oct 5, 2010 | 11:51 PM
CurrentlyPissed's Avatar
My clutch squeacks like a sonovabitch! I need to take it in...
Old Oct 6, 2010 | 08:45 PM
Peezyer P's Avatar
Owch...
I had a problem slightly like this. No matter how far I pushed my clutch in the car still acted as if it wasn't pushed down far enough to go into gear. After I pumped it a few times it would go back to normal, but within driving it would go to acting up again. Take it in the shop... That Warranty goes a long way in situations like this.
Old Oct 6, 2010 | 08:49 PM
GeauxSS's Avatar
Took it to the shop...they said there was air in the system so they blead it. The clutch and brakes feel more firm now.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
