clutch pedal squeaking
Old Mar 27, 2009 | 06:47 PM
cresintern's Avatar
i just noticed my clutch pedal squeaks a bit after i shift into a gear and let clutch pedal OUT (NOT SO MUCH IN) i can hear it and feel it slightly , guess that comes with the territory? 09 balt ss/tc sedan 900 miles
Old Mar 27, 2009 | 06:50 PM
tomj77's Avatar
make sure its not ur shoes or anything, mine made a dinging sound and found it was some wires i had run there that was hitting it when i pressed it. might be something like that.
Old Mar 27, 2009 | 07:17 PM
cresintern's Avatar
i'll pay attention next time, but i think it may be pedal making noise, i have heard that is nothing to worry about
Old Mar 27, 2009 | 07:20 PM
EvilleCobalt's Avatar
My old Cobalt's clutch did this since day one. Haven't head it in the TC though. I figured it was just a squeaky joint somewhere on the clutch pedal.
Old Mar 27, 2009 | 07:25 PM
koch1ar's Avatar
my dad asked why mine sqeaked, but my shoes were just wet
Old Mar 27, 2009 | 07:28 PM
Cuda009's Avatar
Mine squeaks every so often. I confirmed it's not my shoes by pressing it down with my hand.
Old Mar 27, 2009 | 08:20 PM
EcotecAddict's Avatar
I get the squeak every once in a while too. My guess is that its probably normal and is most likely due to a squeaky joint for the clutch pedal, maybe because the car is still fairly new and not fully broken in yet. Hopefully it will go away with more mileage (I too have low mileage around 3000) otherwise it might be time to bust out the lube .
Old Mar 27, 2009 | 10:05 PM
MaxVQ35DE's Avatar
squeaks 7500 miles
Old Mar 27, 2009 | 11:18 PM
RYRO14's Avatar
Yeah mine squeaked, all it needs is lubrication and you will be fine and it will stop doing it
Old Mar 27, 2009 | 11:29 PM
ogc's Avatar
ogc
mine does it too... I just sprayed some lube on it and its good to go.
My bigger problem is some heat shield or some **** under the car rattling up a storm
Old Mar 28, 2009 | 02:17 AM
cresintern's Avatar
where u spray the lube to get rid of squeak???
Old Mar 28, 2009 | 02:18 AM
L.P.'s Avatar
My SS/SC did this but not my ss/tc thank god it was so annoying.
Old Mar 30, 2009 | 10:02 AM
JPizzle's Avatar
Hey. Where did Q lubricate it???
Old Mar 30, 2009 | 10:04 AM
mcphatty's Avatar
my '05 does the same thing
Old Mar 30, 2009 | 10:06 AM
JPizzle's Avatar
See, my old 06' 2.4L Cobalt never did this. It never squeeked... But my 09' SS/TC started at like 3,000 miles & is still squeeking at 4,300 miles. I'm not worried about it though.......
Old Mar 30, 2009 | 10:13 AM
mcphatty's Avatar
nothing a little wd-40 cant fix
Old Mar 30, 2009 | 10:20 AM
SportRedLT's Avatar
have you noticed it squeaking when it rains out?? if so its normal. My car, my friends current cobalt and her old one all do it. Water gets up and it gets wet and just squeaks a little but it doesn't affect it at all performance wise. seems kinda cheap i was flipping out too but its nothing to worry about just try and see if its usually happening when its raining.
Old Mar 30, 2009 | 10:52 AM
TrevMo's Avatar
I think it is just because it is plastic and flexes a bit...mine did this for a while and I kept forgetting to lubricate it...then it just went away and has not returned...just wait it out or get a little bit of lubrication up there...
Old Mar 30, 2009 | 10:56 AM
greygoose08's Avatar
mine does so as well
Old Mar 30, 2009 | 10:59 AM
samijo0703's Avatar
i had the same problem.. it went away tho.. i didn't even touch it... dont know if the dealership did or not.. i never said anything to them so i highly doubt it
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
