Code P1287
Old Oct 7, 2021 | 05:51 PM
LyellT's Avatar
Code P1287
Car is throwing code P1287 from a check engine light scan that I did. I changed the MAF sensor and it did not work. I read it could be low fuel pressure, a vaccum leak, or possibly a cylinder misfire. Any suggestions? The cars air fuel ratio is also jumping around. Even when at idle, the rpms don't move but the air fuel does a good bit and makes the bog sound. Any advice I'd greatly appreciate it. It's a 2009 cobalt ss/tc, I just bought it about a week ago and it has a bunch of mods done to it.
Old Oct 7, 2021 | 06:05 PM
A P1287 is not a maf code, it's for BPV failure. The tan housing on the intake side of the turbo is the bpv, three 10mm bolts to remove it (be careful there is a spring that will pop out), inspect the black piece for damage. If it has a Forge bpv then it likely needs unstuck and greased.
If it's not cracked then check electrical connections to the black solenoid the vacuum line is connected to and the vacuum lines.
Old Oct 7, 2021 | 06:10 PM
LyellT's Avatar
The code is P2187 sorry I mistyped it.
Old Oct 7, 2021 | 06:14 PM
LyellT's Avatar
These are most of the mods it has to if that helps
Old Oct 8, 2021 | 08:45 AM
Have you performed a boost leak?
The code points to a small boost leak or a tune issue.
Old Oct 9, 2021 | 11:17 AM
LyellT's Avatar
I haven't done a boost leak test, whats the easiest way to do so? I'm new to this so just trying to learn.
Old Oct 9, 2021 | 07:48 PM
Here is good thread that explains it
https://www.cobaltss.net/forums/how-...9/#post6120333
Old Oct 11, 2021 | 11:49 AM
LyellT's Avatar
Thanks I'll give it a go and see if I can get it
Old Oct 12, 2021 | 06:30 PM
LyellT's Avatar
So I checked all the vacuum lines and intercooler pipes for a leak, the only place I have one that I found is the flex pipe. Would that make that code go off? And what flex pipe is recommended for a cobalt ss tc?
Old Oct 12, 2021 | 07:00 PM
LyellT's Avatar
Also previous owner said it had a demartino fab downpipe and demartino fab cold air intake. Who makes that? I can't find them anywhere online
CGifford
Aug 1, 2020 04:49 PM
blackbear10
Aug 7, 2017 03:33 AM
Mikey851
Oct 31, 2011 10:30 PM
davescobalt06
Oct 31, 2011 02:59 AM
Darkfuzion
May 3, 2010 06:53 PM
