Codes Read...Now What?
So yesterday I put up a post about losing boost as speeds were increased. In fact, it wouldn't let me even go past 2 lbs. Sounds like a cracked charge pipe or intercooler huh? No. I checked today and everything was fine (except my missing fog light :thumbs down
. So I took my Trifecta cable and ran to see what my check engine light was trying to tell me (because it stays on due to no cat anyway).
Come to find out I have 5 codes which are:
1). P0420 - This is for the no cat issue blah blah okay cool NEXT
I NEED SUGGESTIONS ON HOW TO TAKE CARE OF THE NEXT 4...
2.) P0101 - MAF issue...okay NOW WHAT?
3.) P0300 - Multiple cylinder mis fire...which leads to my next two codes...
4.) P0301 - Cylinder 1 mis fire
5.) P0303 - Cylinder 3 mis fire
I'd really appreciate all the advice on how to fix these issues. It makes sense now why I was losing boost. I'm figuring the P0101 MAF issue was making the ECM "learn down". As far as fixing that...suggestions? And how to fix cylinder misfires?
Thank you.
. So I took my Trifecta cable and ran to see what my check engine light was trying to tell me (because it stays on due to no cat anyway).Come to find out I have 5 codes which are:
Thank you.
The bottom three are directly related to the P0101. Unless you misfired cause you suck at NLS... If you werent boosting, you will most likely fix all of the codes with just taking care of the P0101.
As for the MAF... I can guess its a voltage issue, or you have oil in it from your air filter, or oil from the engine. Take it out, check it and clean it. Past that... hopefully someone else has some more insight.
OrangeCoba
Sep 25, 2015 06:06 PM
