Cold start sputter and stall
Old Sep 14, 2011 | 03:26 PM
ForcedSS's Avatar
The past few mornings have been pretty chili in Toronto. I've noticed that on first cold start my car sputters. Almost like it wants to shut off. It only lasts about 3 seconds and then everything is fine. Idle fine. Driving fine. Power is there. No loss. But this morning was different. Ita actually shut off this time. The second start up was fine. Idle, driving and power are all good. No CEL. So today I pulled my plugs and they all look good. I just hit 30,000km. When its warm outside and the car has been siting even 24hrs, it will not do this. Only when its cold out. What could cause this?
Old Sep 14, 2011 | 03:45 PM
strykr's Avatar
maybe a block heater? could just be too cold, but im up in edmonton now and it hits 2*C in the mornings and i dont have a problem, still have no block heater nor do i plan on getting one.
But i dont know last year i ran my car after buying it up in barrie for the whole winter and didnt have a problem.
Old Sep 14, 2011 | 04:08 PM
guitarenvy's Avatar
Block heaters are typically utilized for -18C and below.
Something as simple as your hahn intake can cause this.
Old Sep 14, 2011 | 07:57 PM
ForcedSS's Avatar
I have the K&N SRI now. That never happened with the Hahn.
Old Sep 14, 2011 | 08:25 PM
RYRO14's Avatar
I heard that this issue was caused by oil starvation of the cam phasers. Makes sense because when it is that cold, the oil's viscosity is significantly lower. It used to happen to me on cold starts but ever since I turned cat-warm up mode off I havent had an issue
Old Sep 14, 2011 | 08:31 PM
Mike_peperni's Avatar
I have the same issue since last spring, i seen a couple of members here with the same issue.
The cam phaser thing sound logic, will probably get the car to the dealer soon and see if they can find something.
Old Sep 15, 2011 | 10:21 AM
chitala383's Avatar
My car does this too most of the time. It's quite annoying.
Old Sep 15, 2011 | 10:33 AM
RHZ's Avatar
RHZ
I just bought some and I'm going to run AMS oil 0W-30 this winter. It has the same operating temperature as 5w-30 but it's supposed to be better for cold starts in the winter. I normally have the same problem and when winter starts i'll see if this helps the issue at all.
Old Sep 15, 2011 | 11:08 AM
vahdyx's Avatar
Plugs?
I know superchips can make plugs go bad after a short while. Not sure though, just a thought.
Old Sep 15, 2011 | 01:16 PM
FasterIsBetter's Avatar
Try pulling the plug on your evap purge solenoid. I unplugged mine and it stopped sputtering on cool mornings so I just leave it unplugged. Throws a cel but I can disable it later.
Old Sep 15, 2011 | 02:54 PM
gdubs's Avatar
Check your low side fuel pressure. I had this same problem and it was my low pressure fuel pump
Old Sep 15, 2011 | 05:35 PM
gmtech16450yz
Guest
Posts: n/a
LNF Timing Tables with Idle Help - HP Tuners Bulletin Board
Old Sep 15, 2011 | 11:53 PM
ForcedSS's Avatar
Thanks for the ideas guys. I'll try those out this weekend. Also this problem isnt very consistent. It could do it today like it did this morning and just sputter hard for a second or two and then fine. Temp 11*C. Then now when I leave work at 11pm and 8*C it does not do it. It was colder tonight and no sputter.
Old Sep 18, 2011 | 11:26 AM
gotboost?17's Avatar
Nothin Stock
in for results, mines doint it to the last couple mornings...heres a vid of mine, i think mines the catless tho
grandamGT1's Channel - YouTube
Old Sep 22, 2011 | 07:08 PM
AndrewSS/TC's Avatar
i also have a vid of this uploading now...
Old Sep 22, 2011 | 11:16 PM
Cobalt SS/TC cold start with a couple revs - YouTube
Old Sep 22, 2011 | 11:32 PM
vahdyx's Avatar
Wow, I forgot how loud our cars are without cat warm delete mode. I've been on that for almost a year now.
Old Oct 6, 2012 | 07:59 PM
4g63killer's Avatar
Bump my car is doing the same... So it's the camshaft actuator solenoids?
Old Oct 6, 2012 | 08:24 PM
nhanson's Avatar
My 2.2 does this but runs lean so i think i need more fuel on start up/open loop
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 04:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
OrangeCoba
Sep 25, 2015 06:06 PM
