Coolant temp sensor
Old Jun 28, 2009 | 07:21 PM
Bad05SS's Avatar
Coolant temp sensor
so the pasted few days i have been having a cool a coolant temp sensor problem. well i some calling around to find one so i called autozone first 24 dollard and they will have it by Tuesday, so i called advanced and they had one in stock for 16 buck, so i was like sweet be there in 20 min, i go and pick it up go home and what do you know its not the right one i was like one so i took it back and said this isnt the right one the end for the pig tails arnt the same. he was like well that the one the computer said to use, we did alittle more digging and found the the right one. this is what i dont understand
to get it for a gm motor it 100 buck but saab uses the same part and they want 34 bucks???
i dont get it lol
that's my rant for today
Old Jun 28, 2009 | 07:27 PM
slowswap's Avatar
Why do you think it's the sensor and not the thermostat? I've seen 3 thermostats go, but no sensors.
BTW if you have an LNF, isn't it still under warranty?
Old Jun 28, 2009 | 08:04 PM
Bad05SS's Avatar
i dont have a temp reading just --- and i dont have lnf i posted it in the wrong fourm my b lol
Old Jun 28, 2009 | 08:06 PM
Sunburst_SS's Avatar
did you ever scan the code???? Probably not the sensor.....
Old Jun 28, 2009 | 08:12 PM
Bad05SS's Avatar
its the sensor hard start, spratic idling, fans run consted, stalling after restart, i can pull the fuse and put it back in and it will read a temp as soon as the temp goes up its back to ---
Old Jun 28, 2009 | 08:34 PM
slowswap's Avatar
--- is usually thermostat.
Old Jun 28, 2009 | 08:40 PM
Bad05SS's Avatar
how so? the thermostat has nothing to do with showing you coolant temp readings. the thermostat is spring loaded the spring gets to a certain temp it pops the thermostat open, the ect sensor is what shows you the coolant temp.
Old Jun 28, 2009 | 08:43 PM
Originally Posted by Bad05SS
how so? the thermostat has nothing to do with showing you coolant temp.
if you have a cooling system DTC.....it will do that. Doesn't have to be a bad sensor. Not saying that's not the problem....just saying if that's what your basing it off of, it may not fix it
Old Jun 28, 2009 | 08:47 PM
Bad05SS's Avatar
i have coolant runing through the motor i know that so but i still bought both so i hope im good lol
Old Jun 28, 2009 | 09:01 PM
slowswap's Avatar
Might as well just do thermostat with the sensor.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
