Custom LNF ECM- What Features Should Be Added?
Old Nov 26, 2012 | 03:11 PM
Matt M's Avatar
We are investing in a custom base file for LNF Cobalts. Customers will still be able to tune with HP Tuners. Some of the things that will be added so far include:
Raising the cam control limts to 9000rpm. The factory limit of 7400rpm is way too low for people running large turbos, especially with our cams.
5th injector control. Yes, we might be able to use the ECM and program in the 5th injector tuning. This will allow infinite tuning of the 5th injector if it pans out.
Anti-lag timing table. This would allow us to spool large turbos while staging at the dragstrip without requiring any additional modules to be installed.
I am starting this thread to see how much interest there is in a modification like this as well as what other alterations or additions you guys would like to see. So, lets hear it...
Old Nov 26, 2012 | 04:02 PM
cmiller8006's Avatar
Sounds like some good things. You know theres a few of us now that could use the timing tables. Not sure on the antilag deal, how much boost is built at the line, I can cut 1.70's all day with the wot box and only about 6-8 psi and it keeps the shock on the driveline down at the same time. Everything else is awesome, being able to tune the 5th injector by boost and or rpms is a good thing.
Old Nov 26, 2012 | 04:07 PM
jzehren11's Avatar
ECM and Fuse Block mount in the Glove Compartment! sorry, I know it has nothing to do with the actual tuning :/
Old Nov 26, 2012 | 04:11 PM
Matt M's Avatar
I use timing retard to get the turbo spooled at the line as it is, but the control is not great. Plus, using the tables that are available sometimes results in timing retard during the burnout. Because of the low load, it hits the als cells. With the revised tables, that would be fixed.
I saw as much as 19psi staged with the s262 turbo that otherwise doesn't spool until about a day and a half after you hit a million rpms.
Old Nov 26, 2012 | 04:15 PM
09CobaltSS1's Avatar
So would this be something we can view in table form via hptuners (like the 5th injector contols and such you mentioned) or is it a custom os that would have to be preset by you guys ahead of time? Either way, I would love to see some sort of dynamic limiter to tune the ve tables somehow, specifically at idle to maybe 2.5k-ish. Maybe even limiter controls like you would find in an e67 for fuel/spark/throttle cut controls.
Old Nov 26, 2012 | 04:18 PM
EXsoccer1921's Avatar
can't you tune in some antilag just regularly with hpt? have someone on a wot-box and play with launch rpm then retard timing and whatever else is needed to dump fuel?
i know the adjustable neutral limit can be used as a bandaid launch control, but building some real boost would be awesome. 60' s out the ass on a ko4 building boost on the line
EDIT: nvm just saw you posted as i wrote that.
couldn't have said it better. so glad we went back to a 59mm on my car
Old Nov 26, 2012 | 04:20 PM
jzehren11's Avatar
that would be awesome!!!!
northvibe's Avatar
Launch control rpm change? is that in HPT yet? I've been out of this for a year or more so I haven't kept up.
INFE's Avatar
not to throw you off topic but what about a custom LSJ computer? higher rev limit and higher maf readings, or better yet a speed density set up. i would buy that from you faster then i could type my credit card info in lol
Old Nov 26, 2012 | 04:25 PM
speed density on our cars?
Old Nov 26, 2012 | 04:40 PM
INFE's Avatar
that maf is just a restriction for me now. it would be great just to get rid of it.
Old Nov 26, 2012 | 04:42 PM
how much do you plan on making?
Old Nov 26, 2012 | 05:03 PM
Matt M's Avatar
Yes, you would be able to adjust the 5th injector control.
I'm not sure on the VE. That seems like it would add a lot of complexity.
Old Nov 26, 2012 | 05:17 PM
T-Man's Avatar
Talking
How about ETC scaling, ultra lean burn capabilities and knock sensor scaling/decay rates
Old Nov 26, 2012 | 05:20 PM
INFE's Avatar
on my stock motor i was maxing the maf by 5600rpms and that with all the tables halfed so i need something better for this motor.
Old Nov 26, 2012 | 05:28 PM
thats crazy
Old Nov 26, 2012 | 05:44 PM
Matt M's Avatar
Did you run an AFC? We used MAF fueling on Ryan's LSJ all the way to 900whp.
Old Nov 26, 2012 | 05:46 PM
terry11's Avatar
subd
Old Nov 26, 2012 | 05:55 PM
INFE's Avatar
nope. which one did you use? i didnt think anything like that was available for the cobalt.
Old Nov 26, 2012 | 06:00 PM
BlkWdoSS's Avatar
what size IC piping are you running, You can manipulate the MAF reading by going to larger IC piping in the MAF area, used to do that a lot in the DSM world
Did Ryan's car use an AFC along with HPT?
would it be possible for us LSJ guys to see some of these PCM upgrades lol.
Old Nov 26, 2012 | 06:01 PM
not sure if its the one used on ryans car but this one is whats on mine.
Easy Performance - Mini AFC Air Fuel Controller for Cobalt/Redline #EP-AFC12-CBT
Old Nov 26, 2012 | 06:31 PM
INFE's Avatar
cool thanks
Old Nov 26, 2012 | 06:57 PM
FF_ace's Avatar
Very interested here
Old Nov 26, 2012 | 07:14 PM
BLOWN GOAT's Avatar
Sounds good to me I'm tired of the wotbox already
Old Nov 26, 2012 | 10:51 PM
cdnite's Avatar
Here is my wish list:
Smart NLS
Selectable Launch Control
Boost During Launch
Selectable Tunes
Ghost Cam
More visable tables that I know are in the tunes
And a feature I know for a fact the Bosch ECU can do, Rev matched down shifts... not that I need help... but it would make us cool like the 370Z guys
--Christian
And for myself, a output trigger for my PLC
