Custom LNF ECM- What Features Should Be Added?
Old Nov 26, 2012 | 10:57 PM
Omnigear's Avatar
matt why not list what is possible additions ^_^
Old Nov 26, 2012 | 11:09 PM
Fastgti69's Avatar
Interested in how you unlock it to be tunable after 7.4k rpms. Revving to 9k and having it tuned properly can make a nice difference in power when you have the turbo to back it up.
Old Nov 26, 2012 | 11:10 PM
brant's Avatar
done through trifecta...?
Matt M's Avatar
Originally Posted by INFE
nope. which one did you use? i didnt think anything like that was available for the cobalt.
Easy Performance - Mini AFC Air Fuel Controller for Cobalt/Redline #EP-AFC12-CBT
Old Nov 26, 2012 | 11:14 PM
Matt M's Avatar
Originally Posted by BlkWdoSS
Did Ryan's car use an AFC along with HPT?
would it be possible for us LSJ guys to see some of these PCM upgrades lol.
Yes, we used HPT.
We already had a bunch of this type of stuff for the LSJ a couple years ago. From our LSJ turbo kit page:
•Adjustable launch control rev limiter 2500-5500
•Raised ceiling for MAF sensor table for much higher HP potential
•ECM tuning capability for boost levels up to 28psi
•Full MAP scaling adjusts fuel up to 25psi boost pressures
•Revised cooling fan control capabilities
•High octane mode
•Nitrous input
Old Nov 26, 2012 | 11:15 PM
brant's Avatar
sooo this is great news for us guys running the big turbo ..rev wise im hoping?
Old Nov 27, 2012 | 02:47 AM
casionerd's Avatar
village idiot
Two things:
1) Make gauges sweep on startup like on some motorcycles, BMWs and Subarus. I don't know if that's even possible.
2) Make a "roll racing" tune.
Old Nov 27, 2012 | 12:09 PM
Matt M's Avatar
I don't have any idea what all is possible. We are just taking suggestions and then looking into them if there are any reasonable ones.
Old Nov 27, 2012 | 12:12 PM
padlock's Avatar
it was mentioned already, but an adjustable launch control would be an awesome feature
Old Nov 27, 2012 | 12:19 PM
Fastgti69's Avatar
I'm not sure if this can apply here. A tuner out here OE tuning makes some of his launch files by having a rev limit set at 1st gear around 3k rpm. Tuner for SC m3's and c63 amgs.
Old Nov 27, 2012 | 12:31 PM
  #36
padlock's Avatar
I've seen people use their neutral rev limiter as a "launch control" in HPtuners, but having a more professional way of doing it would be preferred imo
Old Nov 27, 2012 | 12:39 PM
  #37
dakotaspeir's Avatar
#cobalthoes
Trifectas ecp tune is pretty much speed density. So it's possible to run it but im sure there are tweaks you could do to open it up more
Old Nov 27, 2012 | 06:03 PM
  #38
CMVsst2010's Avatar
I'm definitely interested in this. sounds great! looking forward to how this develops. having the opportunity to rev out to 8-9k would be sick! I also like the idea of adjustable launch control. keep up the good work guys
Old Nov 27, 2012 | 06:16 PM
  #39
jonathan923's Avatar
subd
Old Nov 27, 2012 | 06:18 PM
  #40
Stamina's Avatar
I've got one...
An Ethanol mixture virtual sensor or input for a physical sensor.
Automatically adjusts for the Ethanol content. It'd allow people to fill up on whatever they want, whenever they want, and also do away with the wandering trims with every tank for those that do mixes or as seasonal-mixes change.
Old Nov 27, 2012 | 07:16 PM
  #41
Omnigear's Avatar
Originally Posted by Stamina
I've got one...
muthafuckin win right here
give this man some boobiez to motorboat
Old Nov 27, 2012 | 07:35 PM
  #42
nhanson's Avatar
I've got one...
I like this one
Old Nov 27, 2012 | 07:41 PM
  #43
Omnigear's Avatar
Originally Posted by nhanson
I like this one
make it happen ^_^
Old Nov 27, 2012 | 08:29 PM
  #44
casionerd's Avatar
village idiot
I've got one...
I proposed this in September in the tuning section. Only two people responded so I sent it to Vince.
I said this:
Why can't a Cobalt (particularly an LNF) be "retrofitted" to run E85 with a tune that adjusts timing due to whatever percentage of ethanol is currently going through the fuel lines?
Maybe using something like this:
TTP Engineering
or some other E85 content analyzer.
This would be great. If you want power you just add more E85. If you're in a place that doesn't have E, you can use pump gas. If you've got a mix, no problem.
This is what he said:
It’s a good idea, and that’s basically how the LHU does alcohol calculations, but the question is what input on the ECM are you going to wire it up to?
Then I said this:
That's waaaaayy over my head. I just come up with the ideas. You gotta do the hard part. LOL.
Then he said this:
I guess my point is there’s no input to use for that, so we can’t do it.
Then I said this:
bummer. I still say it was a good idea though. lol
If someone can find a way to do it with HPT..... instant millionaire.
Old Nov 27, 2012 | 08:39 PM
  #45
tomj77's Avatar
i wish the factory limit was 7400rpm. to bad its actually 6200 and if ur stage one 6500
Old Nov 27, 2012 | 10:48 PM
  #46
blrt's Avatar
I am really more interested in a tuneable 9K rpm more then anything. Especially when my future will include an engine build in the near future.
Old Nov 27, 2012 | 10:53 PM
  #47
Stamina's Avatar
I said this:
TTP Engineering
Then I said this:
Then he said this:
Then I said this:
Well, 2 things...
1) This was a custom ECM idea, and nobody said there couldn't be hardware differences, so I took it as a blank slate kind of question. If it really is software only, then on to number 2...
2) If you do it virtually with the O2 sensor, like some cars are programmed to do now without the dedicated tank sensor(s), then you won't even need the input.
Yes please!
Old Nov 27, 2012 | 10:58 PM
  #48
Matt M's Avatar
Limit for what?
Old Nov 27, 2012 | 11:01 PM
  #49
Matt M's Avatar
I think the Ethanol blend calculations could be done. It would have to be kept fairly simple, though. We won't be able to have a bunch of charts to make adjustments.
Old Nov 27, 2012 | 11:58 PM
  #50
EXsoccer1921's Avatar
have you seen ko4 dynos??
that thing has no bid'ness gettin all up in that 7,400 nonsense.
