Daily Driven E85/93 Octane Mix
Old Dec 23, 2010 | 09:47 PM
Spins All Day's Avatar
Can this be achieved without any long term damage to gaskets and seals? I have 3 E85 pumps within 10 miles of me and want to run 50% E85/ 50% 93 Octane.
Does any one think this will be ok for a year straight at least?
Old Dec 23, 2010 | 10:17 PM
FF_ace's Avatar
ive been running that mix for awhile now with no problems
Old Dec 23, 2010 | 10:23 PM
I am going take about 5.5 gallons of E85 when I get retuned and mix it with a half tank of 93 then put it straight on the Dyno.
Old Dec 23, 2010 | 10:39 PM
Iam Broke's Avatar
6.6 gals is half a tank, been running the 1:1 blend & higher up to E85 since last summer, prob ~10k miles. I was the first guy to post about trying this in an LNF, might not have been the first overall, but made it public knowledge we can. A long couple of threads on the HPTuners forum I started.
Lost an injector seal in the head (literally). It was never there, no pieces or remnants found. I don't think it was E85 related. Compression was always lower on #3 until I replaced that injector. It finally lost the fit on a strong pull at 24psi after 50k miles & started misfiring.
Old Dec 23, 2010 | 11:13 PM
RYRO14's Avatar
I've had no problems with my mix tune.
Old Dec 23, 2010 | 11:43 PM
paintballerr78's Avatar
see i was goin to do this but the thought of being a chemist at the pump everytime i go to fill up would suck...So i might do it now and just basically run it to empty then just fill up 6 gallons of each
Old Dec 24, 2010 | 12:20 AM
RYRO14's Avatar
A chemist? It is easy, just add even amounts of each in the tank (5 gallons E-85/ 5 gallons of 93).
Old Dec 24, 2010 | 01:17 AM
T-Man's Avatar
Good stuff. Won't turn back
Old Dec 25, 2010 | 01:40 PM
silverbullet08's Avatar
ive been running it sometime now and i love it. Does kinda suck at times when im low on gas and i have to drive 15 miles to the nearest pump but i usually keep a full tank and just top it off any time i drive by there. This is the least expensive most hp for money gain you can get if you have your own tuning software.... well it really cost nothing.... actually saves a couple bucks at the pump lol.
Old Dec 25, 2010 | 05:19 PM
Retunes for me are only 100 dollars so I am going to maybe add a cold pipe and then the E85 mix and get re tuned.
Old Dec 25, 2010 | 05:28 PM
Murdered SS's Avatar
If i mix 50\50 do i have to do anything else to the car or just a tune. What would happen if i run it like that without a tune?
Old Dec 25, 2010 | 05:35 PM
You will run lean as **** I would imagine since you are making more power with not as much fuel. You shouldn't need to do anything other than getting the E85 and getting it re tuned by someone who knows what their doing. The fuel lines and gaskets should be ok (hopefully)
Old Dec 25, 2010 | 05:39 PM
oh ok Thanks for the advice i need a tune anyways but trying to look for someone around me to do it.
Old May 23, 2014 | 03:08 PM
knissel's Avatar
Here is something that I made that helps me get my mixes for the desired E%:
E85 Calculator for Mobile Android iPhone
Still making improvements to it and would apprieciate feedback on if this is useful or what features would make it more useful for performance people.
Hugger1975
Oct 15, 2015 03:28 PM
Oct 13, 2015 09:32 PM
jmelton327
Sep 26, 2015 10:04 PM
