dashdaq
dashdaq
anyone with a dasdaq know how to get hp reading?
and why is there no entertainment option in the menu like there is supposed to be? and why is there no boost sensor? i ordered gm enhanced stuff, but it doesnt seem like i got it
To get the hp you will need to take the absolute pressure and subtract the outside barometric pressure using the dashdaq scaling feature......
For the entertainment you may need to re-flash your unit... there is only so much internal memory so many times it is an option that is not installed as part of the default. You will probably need to give so things up in order to make room for it...
The gm enhance stuff will also require a re-flash... the end of your manual (see your install cd) will step you through upgrading your unit. Follow the instructions exactly and you will have no problems...
Make sure you get the latest firmware through the update tool.
Can i cut off the can connecter off on obd cable and wire in 2 cables going to 2 diff things, (dashdaq and elmcan) onto one can connector, i dont see why it wouldnt work, unless there is some kind of interferance cross talk type junk.
ok i finally got this stuff figured out, now does any one know how to get a real a/f ratio signal instead of raw voltage? formula or whatnot
well I for the A/F ratio I used the lambda and multiplied by 14.7 using the scaling feature... There is a section in the rear of the manual that gives and example of calculating boost... You can use the same application for the A/F ratio... For your torque there is actually a calculator. All you have to do is scroll through your signal options until you come to the calculators... Correlate the proper sensors (it will ask for certain inputs) and your done....
Pretty much everything you need will either under general parameters, calculators, or scaling....
I think that I had to add my scaling parameter as an option... basically I chose an open parameter (something like parameter d - which was unassigned) and assigned it the scaling parameter. I then programmed whatever I wanted into the scaling option... It will walk you through the scaling features...
If you still have questions, let me know and I will look at my unit more closely tomorrow and answer them....
with a/f ratio, what input did u use as the offset?
ya i did the hp/tq thing in the book and used the sensors they told me, but im reading like 150 of both when i give her, that doesnt seem right at all. why is the numbers so far off, i cant even get over 200. how do i adjust that? im attempting to do the a/f ratio, ill let u know how it goes
As for the hp I get the same thing. Most I can get it to is like 150 which I know is not right. I'm a bit disappointed in that feature myself, but it could be I don't know how to use it right.
Guys for your hp keep in mind that you will not see dyno numbers... What you will see is 'at the wheel numbers' which will look pretty low... while 150 is low... On a STi we recorded about 215 hp and on my tuned Coby we saw about 230.... The 215 hp on the STi was consistent with the research pulled for 'wheel hp' on the stock STi (stock hp = 296), so I know the system is reading correctly.... Basically there will be a correction factor that you will need to determine to get your 'hp' numbers... In my case 230 ~ 310 hp....this matches very well with other dyno numbers using the same tune.
btw... xray...let me know when you are coming to miller... I live about 5 mins away ...perhaps we could meet up.....
kmandevi
Nov 30, 2008 08:42 AM
