Deciding on DP and best way to install.
So I been looking under my car just to get some ideas on deciding which dp to get. What is the best way to get your stock dp off. I have a jack at home to use and was getting some feedback and tips how to remove the dp like what tools to use, how to take off the oxygen sensor, etc. Anyone have any preferences or any ideas?
hahha.
the 3 bolts come off easy or i mean are accessible. the 4th being the top left, requires some extensions and a joint to get off.
May want to use that spray stuff that helps get off told bolts...forgot the name.
Air tools
I didnt have the elbow grease to wrestle the turbo side bolts off myself...lol..it was easy once I borrowed the compressor.
Oh and maybe some anti seize for the sensor just incase you need to take it off in the future.
with the car jacked up, crawl or roll under it. unbolt the O2 sensor(s) first and then the 4 bolts up at the turbo. then undo the catback off the hanger before the rear axle, unbolt the 3 bolts from the dp to catback. undoing the catback off the hanger will allow easier access to the top bolt on the triangle flange. for installation, go in reverse order.
