Deciding on DP and best way to install.
Old Apr 23, 2010 | 11:31 AM
efactor's Avatar
Question Deciding on DP and best way to install.
So I been looking under my car just to get some ideas on deciding which dp to get. What is the best way to get your stock dp off. I have a jack at home to use and was getting some feedback and tips how to remove the dp like what tools to use, how to take off the oxygen sensor, etc. Anyone have any preferences or any ideas?
Old Apr 23, 2010 | 11:33 AM
BYT*SS*TURBO's Avatar
Best way to get it off is to unbolt it and remove it..
Old Apr 23, 2010 | 11:35 AM
northvibe's Avatar
hahha.
the 3 bolts come off easy or i mean are accessible. the 4th being the top left, requires some extensions and a joint to get off.
May want to use that spray stuff that helps get off told bolts...forgot the name.
Old Apr 23, 2010 | 11:41 AM
PB Blaster.
Old Apr 23, 2010 | 11:44 AM
1badBlueberrySC's Avatar
zzp and 4 jackstands, some penetrating oil, a set of sockets, and pull it off, oh yeah an o21 sensor wrench just for ease!!
Old Apr 23, 2010 | 11:45 AM
cubaniche's Avatar
Air tools I didnt have the elbow grease to wrestle the turbo side bolts off myself...lol..it was easy once I borrowed the compressor.
Oh and maybe some anti seize for the sensor just incase you need to take it off in the future.
Old Apr 23, 2010 | 11:57 AM
wantedSS/TC's Avatar
with a lift. 10 min install/removal.
under the car took about 35-40 mins the first time I did it.
Old Apr 23, 2010 | 11:58 AM
You don't need a O2 socket for the DP, just the front O2. 7/8" wrench works quite well.
Old Apr 23, 2010 | 12:04 PM
I didn't say you have to.... I said for ease!
Old Apr 23, 2010 | 12:16 PM
rallycobalt06's Avatar
with the car jacked up, crawl or roll under it. unbolt the O2 sensor(s) first and then the 4 bolts up at the turbo. then undo the catback off the hanger before the rear axle, unbolt the 3 bolts from the dp to catback. undoing the catback off the hanger will allow easier access to the top bolt on the triangle flange. for installation, go in reverse order.
Old Apr 23, 2010 | 12:26 PM
I wasn't meaning for it to sound like I was correcting you
Just letting the OP know he didnt NEED a special tool.
Old Apr 23, 2010 | 12:43 PM
cubaniche's Avatar
Yeah a big wrench came in handy to undo and bolt back on the o2 sensor. I used ramps btw. Still have to purchase some jackstands and a jack
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Oct 21, 2015 11:57 PM
tomj77
Oct 4, 2015 11:39 AM
