dejon spring upgrade question
Old May 18, 2009 | 11:14 AM
  #51
reign1's Avatar
i have it sitting in my room. i never put it in
Old May 18, 2009 | 12:44 PM
  #52
wantedSS/TC's Avatar
x2. It's in my garage, but never installed even though it's on my signature. I need the change that!
Old May 18, 2009 | 12:47 PM
  #53
reign1's Avatar
lol. Im still waiting for my CP.
im scared to see how hard it is to install. i heard it was kind of a bitch?
Old May 18, 2009 | 12:49 PM
  #54
PimpLay2's Avatar
charge piping is easy to install?
i had no problems... if you do it by yourself its a bitch
  #55
you mean DP??
I'm not too sure what a CP is!
Old May 18, 2009 | 12:51 PM
  #56
PimpLay2's Avatar
Originally Posted by wantedSS/TC
you mean DP??
charge pipe
Old May 18, 2009 | 01:03 PM
  #57
julius41282's Avatar
I did mine by myself...it was def. more difficult than I thought it would be. Can def. hear the air rushing through compared to stock.
Old May 18, 2009 | 01:05 PM
  #58
charge pipe
Ahhhh! thank you!!!
who'd you order yours through?
Last edited by wantedSS/TC; May 18, 2009 at 01:05 PM. Reason: Automerged Doublepost
Old May 18, 2009 | 01:20 PM
  #59
PimpLay2's Avatar
from pittsburgh eh???? we might have to meet up sometime.... and yea if you do it by yourself the intake manifold and lower charge pipes are a BITCH!!! to do
Old May 18, 2009 | 01:21 PM
  #60
you should come to the August 1st meet at ridley creek state park 20 minutes west of Philly if you have the day off!!
Old May 18, 2009 | 01:25 PM
  #61
PimpLay2's Avatar
yea i was debating coming to that meet but I have a daughter due around that time and I cant chance missing her birth
Old May 18, 2009 | 01:31 PM
  #62
completely understandable! Hope everything is going well with the pregnancy so far!
Old May 18, 2009 | 02:09 PM
  #63
PimpLay2's Avatar
i appreciate it bro!
Old May 18, 2009 | 03:02 PM
  #64
Dejon. Got hot pipes only with the HKS flange welded on...sounds and looks great.
Ya, I'm from the Bridgeville area...south of Pittsburgh. I have only seen a few SS/TC's around. Making sure everything lines up correctly was the most time consuming for me. Just wanted to get it done right the first time cuz that **** gets hot quick!!
Last edited by julius41282; May 18, 2009 at 03:02 PM. Reason: Automerged Doublepost
Old May 18, 2009 | 03:49 PM
  #65
Gestapo007's Avatar
FTMFW! I got my Dejon with Greddy RS put on saturday night. Sounds and looks sexy.
I have the spring upgrade in and with my greddy it sounds like im getting some compressor surge under low boost. I dont see how this is remotely possible though casue I have my greddy set to really soft, and I technically have 2 BOV's untill my Block off plate comes in. Under high boost its one solid blow off. but under 5lb's of pressure it goes psh pshhhhhhh. i dont know if thats the 2 different BOV's opening at different times though. my buddy ahs the same setup with stock spring and he doesnt have this problem. im thinking under low boost and the stiffer spring rate of the stock BPV it opens later. When i get home from work today im gonna switch back to my stock spring and see what happens. If i can find the stock spring that is. Called a local performance shop and they said that as long as its under low boost ill be fine for now. And im quoting now "Youll hear people swear up and down that it will kill your turbo but if your getting a little surge at like 3lb of boost, youll be fine. if you are getting it at 15lb's then youll have a serious problem" he told me to wait till my block off plate comes in and then see what happens.
sounds cool as **** with that little surge though lol. while im normal shifting down the highway it flutters a tiny bit and when i gun it, it screams. im gonna take a vid today
Old May 18, 2009 | 05:30 PM
  #66
80vetteL82's Avatar
Originally Posted by Terminator2
No boost or no bypass at all depending on the position it sticks in. Either way it is not good.
Yah I finally took mine out and put the stock one back in. I had to take the whole intake off because it was blocking one of the screws to the BPV cover. Suprisingly the intake went back on very easy, it lined right back up.
I actually like the sound without the spring better. I like the sound of the intake sucking air without the annoying "chirp" during shifts...that sounded like the car was sick or something. It still sounds great, just not as loud as with the spring, and now I dont get any fluttering like I was getting under light throttle.
Old May 18, 2009 | 07:11 PM
  #67
Terminator2's Avatar
I agree completely.
Old May 18, 2009 | 07:18 PM
  #68
nate08sstc's Avatar
my question to everyone that is knowledgeable on this subject is if it will be good/better for my car with tune i recently got my car tuned and my by pass valve spring got stuck and seems to me like it might have a boost leak.... and for all of those that say not too put it on will it still burn up my solenoids if i have a tune? (I'm not putting this **** on for the "sweet" noise that it makes)
Old May 18, 2009 | 07:22 PM
  #69
If it got stuck maybe you need a new spring or maybe the BPV diaphram is not seated properly that would cause a boost leak too.
Old May 19, 2009 | 12:41 AM
  #70
08inBama's Avatar
Dealership. It is the BPV spring IDK what the part numbers is. I would ask Maven if I were you. He will know.
I PM'd him about it
been going through all my **** trying to find it, I saw it a couple of days ago and its gone missing now, lol
Old May 19, 2009 | 10:38 AM
  #71
shiftingloco310's Avatar
After reading this post i went and removed my dejon spring and put the stock one back in...The funny thing was that at idle with the dejon spring in i would hear like a knocking noise under idle...put the stock spring back in and no more knocking noise. Must have been compressor surge or something. My only drawback is that my intake wont stay on tight. The couple dejon gave me just doesn't fit the turbo inlet snug enough and through hard shifts it moves. I ordered a coupler reducer( 2.25x2.75) to see if i can get that to work.
Old May 19, 2009 | 11:22 AM
  #72
2.25 is kinda small. IIRC the inlet on the turbo is 2-3/8 or so.
Old May 19, 2009 | 11:32 AM
  #73
PimpLay2's Avatar
always better to go small.... then u just heat it up and make it bigger for a more snug fit
Old May 19, 2009 | 11:35 AM
  #74
As long as you can get it to fit. You might have to lube it up first though.
  #75
PimpLay2's Avatar
nothing lube cant do LMAO
