Dejon SRI installed
Nope it will rub on the bolt for the stock air box and the A/C pipe. I got steel pipe and put a rubber piece on the bolt, not to worried about the A/C cap because that whole line moves pretty easily so it shouldnt be a problem. I think that these companies should make a SRI/CAI kit, is it just me or do you think it would be easy enough to bend a pipe that would go through the fender and everything and connect up to where the filter connects to on the SRI, with a coupler and move the filter to inside the fender? They could offer the pipe for another 50-75 bucks and we already have the filter, and if you live in a climate that gets bad winters and such you could just swap them out with ease.
You can, but ideally you should log data after you install the intake to make sure your fuel trims are not way out of wack. You need someone with HP tuners and a laptop. Unless you have a RPD I believe they can check A/F and fuel trims.
Nope, I had the same problem myself. I sent the intake in to Dejon(from hawaii) and he repowdercoated and added the flange w/hose and got it last Tuesday. Quick turn around. But yea, the stock box screw and AC lines had made their mark on my intake.
Delta coupe
Sep 30, 2015 08:11 AM
