Dejon Turbo Spring
Old Feb 15, 2009 | 02:41 AM
Hill1513's Avatar
Dejon Turbo Spring
Anyone replaced their stock spring yet? Just wondering on how long/difficult of a job it is.
Old Feb 15, 2009 | 02:44 AM
stg2ss's Avatar
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/just-bought-dejon-spring-151400/
Old Feb 15, 2009 | 10:10 AM
Terminator2's Avatar
It does not take too long. Remove you intake from the turbo. Unbolt the tan plastic cover for the BPV. Then carefully remove the stock spring and seal. be carefull as the spring is compressed and can shoot across the room. Install the new spring on to the cover piece and the rubber seal. Compress the spring into the housing as you start the bolts for the cover. Be careful not to overtighten the bolts as you will crack the plastic cover Just snug them down good. It takes around 20 min total if you are not rushing through the install.
Old Feb 15, 2009 | 12:46 PM
cmiller8006's Avatar
I put the new spring and an intake on, took about an hour total. Probably could have been done quicker but I took my time.
Old Feb 15, 2009 | 02:34 PM
Hill1513's Avatar
Thanks guys.
Old Feb 15, 2009 | 02:38 PM
RBC's Avatar
RBC
With the right tools it took about 15 mins.
Old Feb 15, 2009 | 06:03 PM
hiltu's Avatar
to remove intake, use a socket not screwdriver, its a lot easier and with a flexible extension too. i believe its 8 or 10 MM
Old Feb 15, 2009 | 08:02 PM
platinumrims's Avatar
Originally Posted by Terminator2
It does not take too long. Remove you intake from the turbo. Unbolt the tan plastic cover for the BPV. Then carefully remove the stock spring and seal. be carefull as the spring is compressed and can shoot across the room.[/SIZE] Install the new spring on to the cover piece and the rubber seal. Compress the spring into the housing as you start the bolts for the cover. Be careful not to overtighten the bolts as you will crack the plastic cover Just snug them down good. It takes around 20 min total if you are not rushing through the install.
lol you did this is a room? how'd ya get the car in there? lol j/k j/k
Old Feb 15, 2009 | 09:01 PM
sporttintturbo's Avatar
i installed mine. didnt like it make my hks bov not as loud and made it flutter and made me think of compressor surge. so i took it out.
Old Feb 16, 2009 | 08:08 PM
d2k_01's Avatar
Not hating on the BOV but why would you run both? Just get a blockoff plate and then use only the HKS valve. Would sound much better imo.
Old Feb 18, 2009 | 04:07 AM
cheeper to just t off the stock one.im afraid to unhood stocker. made me feel better leavin it hooked up and my hks was insane anoying loud. switched to a type s
Old Feb 18, 2009 | 07:53 AM
BartSS's Avatar
If I get a block off plate can I still do the spring upgrade. That's the only thing I'm a little confused about
Old Feb 18, 2009 | 08:29 AM
No, becuse if you get the block off plate you will no longer use you stock BPV you will have to have a BOV mounted on your chargepiping.
Old Feb 18, 2009 | 01:37 PM
so something as simple as a spring makes the turbo preform better? why didn't GM make the little stuff like that good. oh, so they could keep the price down on the car... right. just like the plastic under the hood. good thing it can be replaced... that's so unattractive
Old Feb 18, 2009 | 02:05 PM
I has a better sound when the BPV opens. It does not really increase performance much except that it seals a little better and closes faster after you lift to shift so the response time for the turbo is a little better.
Old Feb 18, 2009 | 02:40 PM
BartSS's Avatar
I have an aftermeket bov mounted on the piping
Old Feb 18, 2009 | 02:42 PM
Then you do not need the spring. If you run a block off plate you are basically doing away with the stock BPV.
Old Feb 18, 2009 | 04:06 PM
that's wut id call better performance
haha. does HAHN make one of these springs?
wait so if your gettin a BOV just get a block off plate and you dont need the spring no more?
Last edited by platinumrims; Feb 18, 2009 at 04:06 PM. Reason: Automerged Doublepost
Old Feb 18, 2009 | 04:52 PM
Not much difference from stock honestly. I have the spring in my car I mainly noticed a crisper sound from the BPV.
Supercharged06SS
Dec 11, 2022 04:47 PM
maliki778
Oct 1, 2015 07:39 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
