just bought dejon spring
Old Jan 19, 2009 | 01:17 PM
06CobaltssOrange's Avatar
is it very noticable as for as holding boost stronger. do you actually notice a difference in sound and im wonder how hard the install was? please talk about what you think about it and is it worth the 13.00 bucks?
Old Jan 19, 2009 | 01:21 PM
cobaltssoverbooster's Avatar
use your search there is a massive thread on this spring.
Old Jan 19, 2009 | 01:24 PM
brickerenator's Avatar
massive thread is massive
oh
and
what color?
Old Jan 19, 2009 | 01:36 PM
batboy's Avatar
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/bov-spring-upgrade-145889/
Black08SSTC's Avatar
Hold on one sec, i have the thread in my posts. I also have the spring. here is the thread --->https://www.cobaltss.net/forums/showthread.php?t=145889 It took me about 15-20 mins to install. I removed the Intake from the filter box to the turbo to make it easier. also moved the T-Bolt clamp from the rubber expansion tube to get some more room. Two things were a pain in the ass. The worm clamp holding the intake to turbo, and starting the bolts when you put in the new spring. The new one is alot stiffer and harder to push in (no naughty thoughts). Once you get the two screws started its easy.
Old Jan 19, 2009 | 01:46 PM
well i will be doing this mod with my aem intake and spring upgrade so the sound should be a lot lot louder. Then a tune of course along with my muffler delete 300whp here i come!
Old Jan 19, 2009 | 02:59 PM
Zander916's Avatar
Exactly my thoughts. Getting the intake off the turbo was the biggest pain of them all for me because the screw was pointed towards the firewall and SLIGHTLY behind the BOV. Plus I have big hands...
I have a tune and then installed the spring later. I DEFINITELY noticed a difference. I can't say for stock... but with a tune - best $10 you will spend.
Old Jan 21, 2009 | 07:33 AM
sporttintturbo's Avatar
anyone have advice if this is a idiot thing to buy when im buying a bov setup anyway. lol i mean im still gunna be runnin the stock one too. didnt know if there was really any actual performace gains
Old Jan 21, 2009 | 12:15 PM
Zander916's Avatar
I can't speak for stock tune but with an aftermarket tune. YES.... I can tell just by seat of the pants there is a gain.
Old Jan 21, 2009 | 06:10 PM
k sounds good im tuned so ima order it its only 10 bucks lol
Old Jan 21, 2009 | 07:15 PM
MaxVQ35DE's Avatar
BOV's dont add performance, please do some homework
Old Jan 22, 2009 | 01:36 AM
Zander916's Avatar
Homework done - if they leak performance is there to be gained.
It's quite common practice for OEM BOV/BPV to be configured as "unbalanced" meaning they will leak at high boost. The reason being to prevent boost spikes. So then upon raising the boost via a tune it is quite possible to have a boost leak.
I would not be one tiny bit surprised if this setup was the same since GM is obviously concerned with keeping that 260 tq held in check via the ECU.
Oct 21, 2015 11:57 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
