Direct bolt-on turbo (ko4 replacement)
Old Jul 26, 2012 | 06:40 PM
  #101
sebleroux08/tc's Avatar
Originally Posted by Chevycobaltss3
Aggressive you can see 370-380 93 octane, conserve and safe dd 350-370 . Timing and the afr is what will be different. I'll explain
I just recently took of my td07 25g turbo and installed the 20g back on because the turbo bearing was seizing. And because people wanted numbers. So I put in 6 gallons of 91 and 6 gallons of89 octane to give people a wider variety of its capabilities for honest all around the world. Well I tuned it highly aggressive and the car managed to take 20* in areas. It wouldn't take as much in areas. Mainly cuz heat and fuel. But it still managed 400whp. And the reasoning is because of I ramped boost in slow, and I gave it a **** ton of timing. Yes it got kr because the heat and has, but te point I made was the turbos capabilities. If I were to tune it on 93 and same aggressiveness I could get 400whp safely ( for my driving habits) since the life of your engine is dependent on the driver.
The 20g flows a little more then the bnr, but what I did was honestly to much and it wasn't safe. It was just to see what they dyno numbers would be.
awh okay i see well that makes alot of sense but you def know how to tune and be safe bu still agressive. i only run 94 octane in my car and was looking at the option of E47 because i only drive back roads and my work is literally 2 miles from my house.
do you know the back pressure psi # for the bnr by any chance ?
Old Jul 26, 2012 | 06:46 PM
  #102
Frogstofall's Avatar
Frog, you have a small wiener. What you say don't count haha
Shhhhhhhhhhhhhhh!!!!
Old Jul 26, 2012 | 06:47 PM
  #103
Chevycobaltss3's Avatar
Back pressure! Lol no I have no clue .
Old Jul 26, 2012 | 07:33 PM
  #104
elecblue06's Avatar
Dart. Base or not your not gonna see anything above 380whp unless your tune is stupid aggressive with ure fuel. The science is there. If you do get your #s your saying (happy dyno) ... The only people I've ever seen dynos from was frog, team ss and Zzp. Never seen one for 440whp but team as is 8whp away lol
drewbroo
398/436 was my best on the mustang dyno on E30. (25 PSI) On the dynojet and 50/50 mix, 441/488 @ 27.5 PSI.
The car is now sold and detuned for 91 OCT @ 24 PSI for a female driver.
K&N SRI, CIA CP's, ZZP IC, Synapse Catless DP, GMS1 sensors, 3'' Catback, BNR2871 E47 blend 18 degrees max timing 393WHP
and hhrsouth put had numbers around the 380 if I remember correctly on 91
Old Jul 26, 2012 | 07:38 PM
  #105
Dart_SI's Avatar
i cant wait to see what how you guys react when 40rty dynos his BNR.
Old Jul 26, 2012 | 07:40 PM
  #106
Dart_SI's Avatar
Originally Posted by elecblue06
drewbroo
and he was trifecta tuned.. i have his same exact turbo too. lol
Old Jul 26, 2012 | 07:41 PM
  #107
FF_ace's Avatar
Hes wasnt trifecta tuned terminator2 tuned him
  #108
it bothers me when graphs don't cross at 5252
40rty will dyno where everyone else does. Same motor but he does have the cams so it should be a little better.
Old Jul 26, 2012 | 07:42 PM
  #109
FF_ace's Avatar
sorry I was taking about drew
Old Jul 26, 2012 | 07:44 PM
  #110
Dart_SI's Avatar
LOL. you got me all confused because i replied right after then turns out you were talking about drew. i thought you were talking about 40rty and hhrsouth.
Old Jul 26, 2012 | 07:46 PM
  #111
Dart_SI's Avatar
term2 is shooting for 470rwhp on 40rty's car. i think hell get pretty close seeing how 40rty is already at 370rwhp on the stock turbo. good tuning goes a long way.
and remember, kappas make less hp to the wheels than cobalts.
Old Jul 26, 2012 | 07:48 PM
  #112
elecblue06's Avatar
hhr i think was TF tuned
Old Jul 26, 2012 | 07:52 PM
  #113
yeah yeah yeah. we are all gonna make around the same power. tuning techniques aren't gonna make significant differences. 5-8whp maybe for those that know what they are doing like ccss3, term etc...
When are you getting back on the dyno Mr. Smarty Pants?
Old Jul 26, 2012 | 07:57 PM
  #114
40rty's Avatar
5th injector too on top of the BNR, we'll see.
Old Jul 26, 2012 | 07:59 PM
  #115
Dart_SI's Avatar
i gotta do a few more things
Old Jul 26, 2012 | 08:01 PM
  #116
The turbo can only flow so much. Haha. I hope you do hit your goal on the dyno. Would be nice to see what your car traps too, 40rty.
Old Jul 26, 2012 | 08:07 PM
  #117
Sully20's Avatar
In for Results, I Love this thread....Had to Bring it Back for another ride lol, Just too much good info in here.
Old Jul 26, 2012 | 08:09 PM
  #118
Sully20's Avatar
So it seems like 400WHP is kinda a stretch for us guys on 93oct for the BNR? Still havent heard many people in this thread talking about the 252et or the 256et? I've heard the 252 is VERY CLOSE to stock spool and can handle 400WHP, True?
  #119
Dart_SI's Avatar
im glad youre a good sport. i can be stubborn at times.
Old Jul 26, 2012 | 08:12 PM
  #120
Dart_SI's Avatar
itl be a while tho. i just had to drop a good amount of $ for a new trans, clutch, flywheel, etc.
i also need new tires.
there may be a surprise next spring for you guys tho
Old Jul 26, 2012 | 08:13 PM
  #121
I wanted to give a good comparison of the K04 vs the BNR2871...
My car put down 362/376 on the stock K04 with the exact same boost, timing and fuel as I have the BNR2871 on. The BNR made 408/383 (not sure why I seem to make less peak torque than most but maybe its the way James has me setup. He'll have to fill in on that one). Thats 46whp over the stock turbo. Not bad in my opinion!
Stock
BNR2871
And b/c I don't think I posted it here (not that its anything amazing...)
Cobalt SS BNR2871 E47 24.5psi - YouTube
Old Jul 26, 2012 | 08:15 PM
  #122
Dart_SI's Avatar
your peak tq comes on almost 1000rpm later than mine. but james likes to do smooth boost ramps, so that could be why. i like my torque.
Old Jul 26, 2012 | 08:19 PM
  #123
I guess my response would be...
I like my trans
I did bust one already too. Haha!
Old Jul 26, 2012 | 08:23 PM
  #124
AARON-SS-TC's Avatar
i like neck snapping torque as well...lol
Frog, your car pulls like a ****...props man...lol
Old Jul 26, 2012 | 08:25 PM
  #125
Dart_SI's Avatar
just means your part of the broken trans club!
anyone else want to join? lol.
