direct injection fail
Old Aug 23, 2011 | 10:17 AM
  #51
umrdyldo's Avatar
Mine didn't smoke worth a crap. Just a great big puff for about 20 seconds. I let it sit for almost a half hour.
Old Aug 23, 2011 | 10:25 AM
  #52
BYT*SS*TURBO's Avatar
You let it sit too long!
Old Aug 23, 2011 | 10:27 AM
  #53
umrdyldo's Avatar
Probably, I figured it would work better the longer it sat. Is that a bad assumption?
Old Aug 23, 2011 | 10:49 AM
  #54
Yea, 5-10 mins max is all you need.
Old Aug 23, 2011 | 10:51 AM
  #55
Gremlin85's Avatar
Do I really have to go home today and make a step-by-step detailed How-To video on this?!
There's so much info everywhere on how to do this haha.
Old Aug 23, 2011 | 10:53 AM
  #56
ATLsilverSS's Avatar
if you have never seafoamed before you might actually use a whole can or so. if you have some miles and have never done it before you probably wanna add seafoam to the engine oil a couple days before you plan to change the oil and you may want to repeat the vacuuming thru the intake till it doesn't smoke any longer
https://www.cobaltss.net/forums/how-...ct-how-255543/
Old Aug 23, 2011 | 10:54 AM
  #57
There are vids on Youtube even. Its a pretty easy thing to do
Old Aug 23, 2011 | 11:06 AM
  #58
jmfselu's Avatar
eye bout ate canz ah see phonee en canyt sees da smowke...am eye doon iyt rytt?!? lol
Old Aug 23, 2011 | 02:22 PM
  #59
FRQ FLYR's Avatar
I recommended a Sticky to (hopefully) give new LNF owners a heads up on this issue. The treatment (assuming it works) is easy.
Personally I haven't tried Seafoam yet; I've used Lucas upper cylinder lube thru the port that connects to the vac tank a couple times and also ZMAXX last oil change. I guess the key is finding something that actually works and getting it to the valves.
Old Aug 23, 2011 | 03:54 PM
  #60
CTFinestTurbo's Avatar
Ive used atf jus not on the cobalt. The atf works really good just dont use alot
Old Aug 24, 2011 | 06:33 PM
  #61
asanti's Avatar
I agree with changing the plugs, def cruds them up. And doing the oil afterward wouldn't hurt either!
I installed a vacuum tee in the vacuum line right on top of the intake manifold then ran a line off of that. Keep your finger over the line when not sucking in the seafoam and do a lil at a time. I recommend using a clear glass like I mentioned before so you can watch what you are doing. You DON'T want to suck it in quickly or stall out the car IMO. It should take 3-5 mins to suck in 1/3 of the bottle of Seafoam. Let it idle for another 30-60 seconds after and then shut the car off and wait 10 mins. Start it up, idle it for a min then drive normal for a few mins or until the smoke clears up. It will smoke A LOT LOT LOT LOT LOT lol.. This is normal, don't be alarmed. If you Youtube Seafoam you will find some examples of "the show" lol.
Did you have any problems blowing the cap of the tee Nick? Reason I ask is I just did the same thing and the cap keeps popping off.
Old Aug 26, 2011 | 06:22 PM
  #62
BlackLsCoupe's Avatar
Originally Posted by CTFinestTurbo
Where and how does it get done?
we got this company out here got BG makes this induction kit with a tool that sprays into your throtle body it cleans off the throtle plate as well as intake and exhaust valves and cylinder heads. its like $160 or so at the dealer.
Old Aug 26, 2011 | 06:58 PM
  #63
SSlobalt's Avatar
If you use the vac port on the coldside pipe, that would clean the throttle body, right?
Old Aug 26, 2011 | 07:40 PM
  #64
slowstang's Avatar
To be honest if the car is already has 30k miles I can't see seafoam doing much to the carbon buildup. It wasn't easy at all to come off.
Old Aug 27, 2011 | 11:57 AM
  #65
vahdyx's Avatar
I'm at 16k miles should I seafoam now or wait until 30k
Old Aug 27, 2011 | 12:00 PM
  #66
HHRSSouth's Avatar
Now
Old Aug 27, 2011 | 12:19 PM
  #67
repeat the process until there is no white smoke coming out of the exhaust. it will work it just may take more than one application
Old Aug 27, 2011 | 12:23 PM
  #68
M-Dub's Avatar
it will be happening on EVERYONE with a D/I motors car. It's the same for every D/I motor that I know of actually.
And SEAFOAM works at this... I've done it 2 times now... 12k, and 24k miles.
Old Aug 27, 2011 | 12:46 PM
  #69
how do you do it?
Old Aug 27, 2011 | 12:47 PM
  #70
Boosted4's Avatar
how do you do it?
Check the pages of this thread
Old Aug 27, 2011 | 01:01 PM
  #71
i kno im asking how HE does it.
Old Aug 27, 2011 | 01:24 PM
  #72
dayhoff35's Avatar
subd
Old Aug 27, 2011 | 04:15 PM
  #73
SSlobalt's Avatar
Does running E85 make any difference, or does carbon buildup still occur?
Old Aug 27, 2011 | 06:55 PM
  #74
Bleu's Avatar
Sub'd
Old Aug 27, 2011 | 08:27 PM
  #75
raver0789's Avatar
Forgive me if this is a stupid question, but can't you just take the head off, clean everything out, put a new headgasket on and call it a day?
