direct injection fail
Old Sep 9, 2011 | 12:59 PM
  #101
Leafydialupking's Avatar
Originally Posted by NDCOBALTSS
Would running E85 get rid of carbon after time? ive been running it for the last 3000 miles.
No, because the e85 does not hit the intake valves.
Old Sep 11, 2011 | 01:06 AM
  #102
Bika's Avatar
Fail Less.
Originally Posted by LE5_AJ
How about a little prevention as well what about a catch can setup?
That should help alot.
Old Sep 12, 2011 | 01:36 AM
  #103
NDCOBALTSS's Avatar
WOW!!!!!!!!! did my first sea foam treatment today! i have 42,XXX miles on my car, it made a pretty big difference!!!! quite a smoke show! i wanna put sea foam in my washer fluid reservior and run that line to a T fitting that goes to that vacume line on the intake manifold!!!! lol should I clean my 02 sensor??? it threw some codes but i cleared them and it runs perfect!!!
Old Sep 12, 2011 | 05:43 PM
  #104
VR09Sedan's Avatar
Originally Posted by BYT*SS*TURBO
I agree with changing the plugs, def cruds them up. And doing the oil afterward wouldn't hurt either!
I installed a vacuum tee in the vacuum line right on top of the intake manifold then ran a line off of that. Keep your finger over the line when not sucking in the seafoam and do a lil at a time. I recommend using a clear glass like I mentioned before so you can watch what you are doing. You DON'T want to suck it in quickly or stall out the car IMO. It should take 3-5 mins to suck in 1/3 of the bottle of Seafoam. Let it idle for another 30-60 seconds after and then shut the car off and wait 10 mins. Start it up, idle it for a min then drive normal for a few mins or until the smoke clears up. It will smoke A LOT LOT LOT LOT LOT lol.. This is normal, don't be alarmed. If you Youtube Seafoam you will find some examples of "the show" lol.
Exactly what I was looking for, I seafoamed my car a week ago, and it threw a 2nd cylinder misfire code right after. The car ran just like it did before, after I started it back up and smoked it out. The car actually ran better after the seafoaming with Misfire CEL. I'll be changing the spark plugs soon!
Old Sep 12, 2011 | 11:09 PM
  #105
Boosted4's Avatar
Yea, its usually a good idea to change your spark plugs and oil after a sea foam treatment.
Old Sep 13, 2011 | 07:55 AM
  #106
umrdyldo's Avatar
Nope same issue. No fuel over the valves.
Old Sep 13, 2011 | 08:13 AM
  #107
hawlyns711's Avatar
so aren't the new corvettes supposed to be DI?
Old Sep 13, 2011 | 12:30 PM
  #108
T-Man's Avatar
Since the evap purge valve sits in the intake manifold, couldn't we use this as a means of introducing cleaning fluids to the intake tracts and valves as well?
Old Sep 13, 2011 | 12:37 PM
  #109
umrdyldo's Avatar
Originally Posted by T-Man
Since the evap purge valve sits in the intake, couldn't we use this as a means of introducing cleaning fluids to the intake tracts and valves as well?
Intake manifold *
Technically you could T off the vacuum line on the manifold and have a bottle that released a little but I think sticking to periodic use is best.
Old Sep 13, 2011 | 01:17 PM
  #110
T-Man's Avatar
Originally Posted by umrdyldo
Intake manifold *
Yes, the manifold thanks.
I'm not talking about consistent usage. Instead of using a vacuum line, why not just slowly feed through the evap solenoid? Both accomplish the same thing but one seems that it might be a bit easier?
Old Sep 13, 2011 | 01:26 PM
  #111
zrated89's Avatar
hmm i installed my phenolic spacer at about 70k on my lsj, (pics in my thread) intake valves look brand new also only use top tier detergent gasolines as well because that can contribute to yalls issue. And hands down if ANY lnf is tuned they should have a catch can installed. Hell im doing my TVS and will have one on my car
Old Sep 13, 2011 | 02:28 PM
  #112
umrdyldo's Avatar
Type of gas has almost nothing to do with this. Again, Direct Injection
Old Sep 13, 2011 | 02:54 PM
  #113
emiller's Avatar
Yes. A lot of new engines from most OEM'S are direct injection now.
Old Sep 13, 2011 | 03:04 PM
  #114
Bika's Avatar
Fail Less.
Yes, LSJ's will not have these issues. Only LNF and other direct injected cars.
Solaris99
28
Mar 15, 2017 01:22 PM
importkiller
Sep 30, 2015 07:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
