downpipe/exhaust rubbing heatshield
Fail. turbo xs downpipe rubbing heatshield making very uncomfortable and annoying vibrations. it was fine until i put in powells rotated trans mount and rotating the rear of the motor made it rub. i put a clamp to bring it more to the right where it hangs from the cat back to fix it soo ill se how it holds up
My buddy and I just installed turboxs downpipes last weekend. His was hitting the heat shield at the same spot as yours. We used tie wire at the first exhaust hanger to pull the exhaust/downpipe flange farther away from the heat shield. Mine is very close to the shield as well, but haven't heard it rubbing yet. Seems like there should be more clearance as there's a large gap on the drivers side of the flange. Tie wire worked though
