downpipe installation
Old Mar 4, 2009 | 08:47 PM
batboy's Avatar
For those that have installed their own downpipes, what's the ease or difficulty level? I was getting my oil changed today and asked if I could look under the car while it was on the lift. Looks like the upper nut on the driver side is a pain to reach (front of downpipe), especially since I'll be using jack stands instead of a lift. Can you reach that top nut from the top or do you need a socket extension and a swivel?
Old Mar 4, 2009 | 09:12 PM
Hawaiian Whore's Avatar
TOO easy... all you need is a long ass extension for the bolts on the manifold
no swivel, and it was on jack stands as well...
Last edited by Hawaiian Whore; Mar 4, 2009 at 09:12 PM. Reason: Automerged Doublepost
Old Mar 4, 2009 | 09:17 PM
OBZ's Avatar
OBZ
It is really easy especially for just the downpipe! All you need is a good long extention for that top bolt
Here is a how-to i wrote for the header/downpipe. should help ya out a bit
https://www.cobaltss.net/forums/how-guide-43/how-install-header-downpipe-158475/
Old Mar 4, 2009 | 09:28 PM
TCASON's Avatar
https://www.cobaltss.net/forums/showthread.php?t=158475
While this is great for the Supercharged or NA people, it doesn't work for the turbo DP
The DP only has one tight area, and that is the top bolt at the cat-back connection. You will need a long, or maybe two extensions with a swivel joint to get to it. Other then that the rest is easy to get to.
I will admit that I have only done this with a lift, ( several times, for R&D )
Old Mar 4, 2009 | 09:33 PM
OBZ's Avatar
OBZ
oops my bad, I didn't notice the section
Old Mar 4, 2009 | 09:34 PM
batboy's Avatar
I appreciate the link, but that's not for a SS/TC LNF. Our turbo downpipe has 4 holes on the front flange and 3 holes on the rear flange. Looks like the heatshield is in the way on the upper left nut. Oh yeah, the DP heatshield is different on the turbo too.
The rear flange looked super easy to me. It's just the one nut on the top of the front flange that worries me.
Old Mar 4, 2009 | 09:36 PM
glhs379's Avatar
found an easy way to get to that top bolt at the catback flange
unbolt the dp from the turbo first, and undo the catback rubber mount at the first bend, then the whole works comes down and you can get to that top bolt with just a socket and rachet, as it is now well away from the floor of the car.
just put mine on last week. also used a small pipe wrench on the o2 sensor to break that free before I lowered the dp, i love a small pipe wrench for o2's works so nice
not a bad job at all
Old Mar 4, 2009 | 09:42 PM
^^^ that's what i did
as for a swivel, i did not have to use a swivel to get the top bolt off of the manifold, all i used was an extension!
Old Mar 4, 2009 | 09:43 PM
batboy's Avatar
Ok, so I guess the downpipe flange at the manifold/turbo must be easier than it looks.
Old Mar 5, 2009 | 03:55 AM
08inBama's Avatar
when I looked at that write up and saw a header, my mind boggled
it was then I realized it wasn't for a LNF, lol
Old Mar 5, 2009 | 11:20 AM
glhs379's Avatar
dp flange is not bad at all with a 3/8 ext and a swivel ext from behind the rack
the other three are cake
Old Mar 5, 2009 | 11:33 AM
5thGearPinned's Avatar
The hardest part of the install is getting the turbo flange bolts loose. Youll need some long 1/2" or 3/8" drive extensions, prefferably with a swivel feature as it is on an angle. I ended up crossthreading one bolt due to the wierd angle its on and had to have the stud replaced. Be careful, but its a very simple mod to perform. Shouldnt take longer than 30 minutes with the right tools
Old Mar 5, 2009 | 11:55 AM
batboy's Avatar
I have a 10" extension and a couple of 4" extensions plus a swivel. It always takes me 4 times longer to do stuff on my car than everyone else, so if it took you a 1/2 hour, it'll be 2 hours for me... lol.
dennis69
Oct 20, 2015 07:39 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
