Lnf throttle body
Old Feb 26, 2009 | 09:52 PM
YzRider452's Avatar
Lnf throttle body
Can somebody on here do me a favor. I need to know if the Lnf uses a 6 pin throttle body harness or 8 pin. Please someone check for me.
Old Feb 26, 2009 | 10:21 PM
Mazdaboi318's Avatar
Why do you need to know?
BTW i dont know sorry
Old Feb 26, 2009 | 10:48 PM
Jn2's Avatar
Jn2
to see if he can put it on his 2.2 thats why, look at his sig, honestly i dont know man, why a LNF TB? why not a lsj, or fe5? hell a ls4? they have the same pin out as the lsj so u can rewqire per lsj wiring diagram
Old Feb 27, 2009 | 09:45 AM
DGAF260's Avatar
it has 6 terminals
Old Feb 27, 2009 | 09:55 AM
Gestapo007's Avatar
to the op, sorry i dont know, but great 1/4 mile time in sig for an LS
Old Feb 27, 2009 | 04:38 PM
YzRider452's Avatar
I need to know because 07 cobalts use a 6 pin harness, so we cant use the lsj tb. Can someone just confirm DGAFs post that it has 6 pins?
Old Feb 27, 2009 | 05:15 PM
Matt M's Avatar
Yes, it is a 6 pin connector. It also uses a very small throttle plate. IIRC, it is 57mm. It can be smaller on turbo setups since the boosted air charge is compressed prior to the throttle body. If you are looking for an upgrade for the 2.2, I doubt the LNF TB is going to be the answer. If you already know this and need the TB for a completely different reason, then just disregard most of my post.
Old Feb 27, 2009 | 06:09 PM
YzRider452's Avatar
I was looking for a suitable throttle body for a supercharger set up.
Old Feb 27, 2009 | 09:47 PM
Matt M's Avatar
It's too small for a draw-through setup like on an M62.
Does anyone know the TB size on the 2.2? I'm guessing it's about the same as the LNF.
Old Mar 5, 2009 | 12:19 AM
Hotshot768's Avatar
Not sure over here. Not trying to thread jack but does anyone know about any upgrade throttle body's coming out for the LNF's?? is it necessary??
Old Mar 5, 2009 | 05:09 PM
peachpuff's Avatar
Not unless you have a turbo that barely fits in the back, absolutely no point with a stock turbo.
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
