Dump valvue leaking??
Old Apr 2, 2011 | 01:12 PM
504redcobaltss's Avatar
So the other day i noticed i had some oil on the ground from my car. I needed an oil change so i got it done and they showed me where the leak was coming from. The guy said it was coming from the dump valve. He wrote it down for me and it says turbo housing kit clutch system components leaking pts.
Does anyone know if this can be fixed? and if i have to replace it how much it will cost?
also the guy said it was probably because i was running my car really hard.
Any advice would be nice.
Old Apr 2, 2011 | 01:19 PM
peachpuff's Avatar
If by dump valve he means the bypass valve then odds are you've got some oil in the intake through the pcv valve, take the intake and see if there's any oil inside it. And try not to break the nipple on the intake when you take it off.
Old Apr 2, 2011 | 01:20 PM
09CobaltSS1's Avatar
dump valve? did he maybe mean the pcv? Why not bring it in for warranty work?
Old Apr 2, 2011 | 01:22 PM
i would but i have a catless downpipe on
and i didnt notice any oil because i just got a new intake the other day
Last edited by 504redcobaltss; Apr 2, 2011 at 01:22 PM. Reason: Automerged Doublepost
Old Apr 3, 2011 | 12:33 AM
heinen02's Avatar
Just cause you have that dp on doesnt mean they can't do warranty work on your car. Bring it in and make them fix it. Save you the money and hassle.
Old Apr 3, 2011 | 02:49 PM
i thought if i had a new intake and catless downpipe they wouldnt do any warranty work on my car?
Old Apr 3, 2011 | 03:40 PM
that tends to vary from dealer to dealer. Some won't have much of an issue with this, and others will. If you're that worried about it, then remove the dp and intake and re-install the stock parts. It shouldn't take much more than an hour or 2 to swap them both out.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
