e brake sucks
Old Apr 6, 2010 | 11:52 PM
toeknee(ss)'s Avatar
e brake sucks
My e brake blows. I live on an incline and when I engage the e brake the car keeps sliding down. Wondering if this has happened to any one else but this sucks. My brother in law told me to put it in gear it holds a little better but it jerks back if u lean on it. Havn't had time to go to the dealership but this really sucks.
Old Apr 7, 2010 | 01:07 AM
silverbullet08's Avatar
same here. you can adjust it a little by pulling the ebrake cover off and tightening the 10mm nut i believe is the size. helped me out a little. there is a little clip on the bottom side of the handle of the brake u have to push in and it should pop off pretty easily
Old Apr 7, 2010 | 01:14 AM
will check when i get out of work thaks.
Old Apr 7, 2010 | 01:20 AM
bryce712's Avatar
i always use gear and e brake for parking personally.
also i thought i remember someone on here posting that reverse was the best gear to park the balt it.
Old Apr 7, 2010 | 03:26 AM
SSlobalt's Avatar
After your dealer mechanic tightens it enough to work, then your inside pad will wear down to nothing. I speak from experience.
Old Apr 7, 2010 | 03:35 AM
frank06silverss's Avatar
I had the same problem,
As it turns out, i jacked the rear of the car and grab a hold of the wheel and tested each side and my right side was not holding, i could turn the wheel by hand !
I went to the dealer and told them to order a new right rear caliper.
After they installed it, the car holds fine now, you can actually feel the difference when you pull the parking brake.
You should be able to lock your rear wheels when your almost stopped.
Frank
Old Apr 7, 2010 | 03:48 AM
mofofernando's Avatar
it could do what mine did where the actually locking mechanism fell out of place and theres no way to put it back in since its pressed in. the whole e brake assembly isnt too expensive nor is it hard to remove and replace but you might wanna try tightening it first and also jack up the rear and tighten the cables going to each brake
Old Apr 7, 2010 | 04:05 AM
thanks 4 the info not really car savy but will check all this out cuz its really frustrating me. my car literaly rolls down the hill a little at a time. MUCH GAYNESS!!!!!!!
Old Apr 7, 2010 | 04:39 AM
Alleynejl's Avatar
Same thing happened to me after I tightened to nut to the ebrake cable I do believe there right that it's 10mm and it works fine only took a few
mins there's 2 bolts n the back of the center counsel piece & it's all clips for the rest to remove it out the way to work with the e brake cable. Hope this helps
Old Apr 7, 2010 | 05:39 AM
i made a how to on taking it all apart but it still hasnt been approved guess they figure its not that important but its super easy to do
Old Apr 7, 2010 | 08:31 AM
kylewalton2007's Avatar
same happened to me, but it ended up being my inside pads worn out
Old Apr 7, 2010 | 09:33 AM
jphugel11's Avatar
it's just the rear brakes. You need new pads/rotors...something in there. I just got mine replaced at the dealer a week ago and the ebrake is MUCH tighter than it was and holds better.
Old Apr 9, 2010 | 04:11 AM
got home the other day parked my car and the e brake worked just fine. Im triping ***** here cuz i havn't moved any thing on the car and e brake works.
Old Apr 9, 2010 | 11:21 AM
SSlobalt's Avatar
Yup. Same thing happened to me.
Old Apr 10, 2010 | 12:12 AM
cobalt9123's Avatar
Do put it in gear....I parked in a steep lot one time and came out seeing my new SS/TC stuck up against a Nissan Armada..shouldn't have trusted the ebrake
Old Apr 10, 2010 | 12:20 AM
RazaMaJazz's Avatar
My ebrake has been shitty since I got my car. I popped the "lid" off and check out the cables. When I pull my break, it only pulls up on one of the cables till the last 2 or 3 clicks, then barely pulls the other.
What should I do about this?
Old Apr 10, 2010 | 01:10 AM
tomj77's Avatar
pull it up higher
Old Apr 10, 2010 | 01:25 AM
ecot3c inside's Avatar
I was washing my car and the motherf@#!er was sliding down my driveway....oh well, I will have to fix that after I pull that god damn nail out of my tire.
Old Apr 10, 2010 | 09:00 AM
Wangspeed's Avatar
Always put your car in gear. The parking brake is only meant to assist. After having once forgotten to set my e-brake or put it in gear, because I was too pre-occupied with the two cute girls I was with, it rolled off into a ditch with the alarm ringing all the way... From that day on, I always set the parking brake, even on automatics.
Old Apr 10, 2010 | 09:27 AM
SSlobalt's Avatar
I hope you got some, at least.
Old Apr 10, 2010 | 05:02 PM
FRQ FLYR's Avatar
https://www.cobaltss.net/forums/how-guide-43/how-adjusting-emergency-parking-brake-05-09-cobalt-w-rear-disc-brakes-168592/
Old Apr 11, 2010 | 06:34 PM
1Rare4Door's Avatar
Mine went in 4 times before they fixed it. First was an adjustment, second was another adjustment, Third they replaced the handle, fourth they replaced the rear caliper which seemed to be the culprit. Have a pretty steep driveway and i barely have to engauge it.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
