E85 Coversion
Old Jun 17, 2013 | 05:03 PM
GreenySC2's Avatar
E85 Coversion
I swear i saw something on here once about running it with some tuning/changes in parts on the LNF but i cant find it.....
Anyone?
Old Jun 17, 2013 | 08:09 PM
Sonicyeller's Avatar
It requires nothing but a tune on an LNF. You can upgrade the injector combustion seals to black 2010+ design if you want or wait until the non-e85 white ones you most likely have fail. I ran my white ones on e85 for about 10k miles before one failed.
Old Jun 17, 2013 | 08:21 PM
GreenySC2's Avatar
so basically throw in some '10 injector seals and add it to the tune and I'm good to go? sweet...
side note flow rate of stock injectors is?
Sent from my Samsung Galaxy Note booyahh
Old Jun 17, 2013 | 08:27 PM
LNFTX's Avatar
Yes
Not enough to run full e85 almost all run half 93 (e47) for two main reasons straight e has horrible mileage and most end up running out of fuel b.c. It takes a higher volume of e85 to make power but if you have corn fuel close by do it you
Will make more power with e47 and a good tune
Old Jun 17, 2013 | 08:33 PM
GreenySC2's Avatar
well almost every krogers i go by between home and work has it so i don't know hah
yeah i know its been shown to put out more power somehow...
eh just another thing to consider in the effort to gain power without a complete engine/turbo overhaul
Old Jun 17, 2013 | 08:36 PM
LNFTX's Avatar
Make more power on corn bc it has a higher octane rating than gasoline meaning you can run higher cylinder pressure thru more timing and the like while still resisting knock
Old Jun 17, 2013 | 08:41 PM
GreenySC2's Avatar
gotcha gotcha
i mean with the tune you can run straight e, straight 93, or a mix right?
again anyone on flow rate of stock injectors?
Old Jun 17, 2013 | 09:00 PM
buildmeanempire's Avatar
20 cc per minute @ 1450 psi
Old Jun 17, 2013 | 09:56 PM
Omiotek's Avatar
your going to run out of a fuel on the stock injection system no if ands or buttss...... on a stock turbo your best bet is to go e47 because with full e85 you will run out on top.
a 5th injector is needed to help deliver the fuel. also i recommend doing the newer viton seals right away dont bother waiting till a part fails. thats stupid logic imho when you know its going to crap out sooner or later. the injector seals are not like your typical mpfi seals either. DI seals need to be sized and require a special tool to do so. just some fyi.
Old Jun 17, 2013 | 10:23 PM
2000Firehawk's Avatar
Running E47.5 for 4 years with the stock white seals...
Display showed that I was getting 36 MPH on my way to the track on Saturday...
Hugger1975
Oct 15, 2015 03:28 PM
Builttss
Oct 4, 2015 10:21 AM
roadrunner132
Sep 16, 2015 09:13 AM
Macgyver2484
Sep 2, 2015 05:44 PM
