Ecotec Fuel Injector tools list..
1 Post
Anything missing? I searched to work with/for most Ecotec GEN 1/2/3 based engines..
Got tired of using either worn, broken or missing tools..
J-37287 Inlet and Return Fuel Line Shut-off Adapters [awesome to diag live (tank/rail) pressure readings - shop has one modified to work with a fuel pressure gauge]
J-37281-A Injector Remover [must have tool]
J-34730-405 Injector Test Light [great to see what injectors is faulty or on/off] ( watching it blink when the inj is on - it's crazy)
EN-48266 Injector Seal Installer [must have tool]
EN-47909 Injector Bore Brush Kit [great to clean the bore after you remove/replace the injectors]
J-44602 Injector Test Adapter [awesome tool to diag sending info to/from ECM, my shop manager has one spliced to use with fluke meter]
J-44175 ALCOHOL TESTER KIT [great to test fuels - e85/race gas] Instructions are pretty straight forward
