Equinox cam options for LNF
Old Mar 8, 2016 | 01:02 PM
  #76
blueLNFftw's Avatar
Did anyone ever check lift on the exhaust cam?
Old Mar 8, 2016 | 01:19 PM
  #77
soundjunky's Avatar
I am pretty sure this info was posted somewhere...
I am subscribed here because I was going to go this route... until I found a great deal on ZZP-stage1 cams with the upgraded lobe.
Old Mar 8, 2016 | 02:11 PM
  #78
YelloEye's Avatar
Post 38. Emphasis is mine.
Originally Posted by rockSTAR_SS
Second, I will show you the difference in lift between the stock LNF intake cam and the Equinox intake cam installed in the head. The first pictures are of the Equinox intake cam at 0 lift and max lift.
Equinox intake cam at 0 lift:
[IMG]http://i1033.photobucket.com/albums/a411/treybyrd89/20140208_113233_zps338ec8eb.jpg[/IG]
Equinox intake cam at max lift (.245"):
[IMG]http://i1033.photobucket.com/albums/a411/treybyrd89/20140208_113350_zpsed181196.jpg[/IG]
Now for the stock LNF intake cam, sitting inside a removed stock LNF head I have on the shelf.
Stock LNF intake cam at 0 lift:
[IMG]http://i1033.photobucket.com/albums/a411/treybyrd89/20140208_113845_zpsfc1231a2.jpg[/IG]
Stock LNF intake cam at max lift (.237"):
[IMG]http://i1033.photobucket.com/albums/a411/treybyrd89/20140208_113957_zpsd8a705ab.jpg[/IG]
Again, this is only an intake cam comparison. I have not compared duration because I do not have a way to do so here at home. I compared exhaust cams, but the Equinox cam had less lift from the beginning. Currently, I have the Equinox intake cam and the stock LNF exhaust cam installed in the engine. The engine is not in the car currently, so I cannot provide information pertaining to that.
Old Mar 9, 2016 | 08:33 AM
  #79
blueLNFftw's Avatar
Interesting.
I was told that there is slightly more lift on the Equinox cam...
Old Mar 9, 2016 | 01:26 PM
  #80
YelloEye's Avatar
Interesting.
Yes but only on the intake cam according to rockSTAR_SS.
Old Mar 9, 2016 | 01:36 PM
  #81
soundjunky's Avatar
/\ /\ if you're able, you should fix your prior post - you typed "[/ig ]" instead of "[/img ]"
Old Mar 9, 2016 | 03:20 PM
  #82
YelloEye's Avatar
Did that intentionally to keep from reposting the images, if you want to see the images you can click the in that post and it will take you to the original post with images. I know scrolling through it on mobile sucks so I usually clip images unless I need them for post reference.
Old Mar 9, 2016 | 03:49 PM
  #83
soundjunky's Avatar
oh... I had not thought of that - that makes sense.
Old Mar 11, 2016 | 07:20 PM
  #84
mongorat427's Avatar
Got these in stock . New Equinox fueling cams. Have 3 left . Bran new $175
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
nathan112i
Sep 30, 2015 07:12 PM
