Equinox cam swap
Equinox cam swap
So I'm doing the cam swap for my e85 mix set up. Just need to know what else I need for the swap. Should I get valve springs? I don't think I should, but some other people think otherwise.
This what I have so far:
2011 2.4l exhaust & intake
Bearing set for lnf (not for sure if it comes with bolts)
E85 hp fuel pump
Opel injectors (stock injector in3rd cyclinder is going bad, keeps miss firing every now and then)
GM Stage 1 sensors
Future parts in july or june:
Rear and front trans mount
Clutch (not for sure what clutch tho)
E85 hp fuel pump
GM Stage 1 sensors
E85 hp fuel pump
GM Stage 1 sensors
E85 hp fuel pump
GM Stage 1 sensors
robk
whats the benefit to Equinox cams? bigger fuel lobe??
nevermind, I just read the whole 2.4L DI Equinox cam swap thread. Matt wanted someone to send them a 2.4 DI intake cam from a 2010 Equinox to check the duration but it never happened. The lift max was definitely higher than the stock LNF intake cam but as far as gains, who knows.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
