Everyone having issues with gms1 chime in!
Old Jul 27, 2010 | 08:31 PM
  #101
lifeguard15's Avatar
Originally Posted by ford
Something else is wrong... you shouldnt be killing turbos that quickly. Are there oiling issues with your return/feed lines to the turbo? the K04 is fairly reliable... its not a mitsu turbo
I lmao at the knock on mitsu turbos.
I'm thinking the loose charge pipe had something to do with the turbos getting chewed up so quick. Actually I'm praying that's what it is, I have no idea. I'm buying an oil catch can soon as an added precaution. I honestly wouldn't know what to look for to see if the return/feed lines are having issues.
Old Jul 28, 2010 | 01:33 PM
  #102
rdskin21's Avatar
car is in the shop for the day, they're replacing the map sensors, but go figure the o-rings didn't come in the package so they need to get them from another dealer. I'm hoping this fixes the problems with this thing. So far it doesn't seem like anyone else is placing blame on the sensors themselves so we'll see.
Is there anything else I should have them look at while it's in there? I'm a bit of a ri-tard with cars once I get under the hood. I have been having the intermitten studdering when getting on and off the gas, fluttering really bad one day, and the random surging on occasion.
I'm going to have them hold the ticket because my warrenty is coming up pretty soon so i'm trying not to get f-ed with a huge bill once something finally does break for good.
Old Jul 28, 2010 | 03:00 PM
  #103
themacguy's Avatar
GMS1 installed by dealer and Zero problems. Nothing but smiles.
Mind you, everything else is stock and I may just keep it that way.
Old Jul 28, 2010 | 03:38 PM
  #104
Bolted-N-LoweredSS's Avatar
problems I had...
#1 Lower sensor didnt sit flush so took off the excess plastic on the charge pipe also where that vaccum line i think it is connects on the lower charge pipe the connector was little broke but i think thats a recall
#2 Top Sensor didnt line up through the whole so drilled it out and then it fit perfect.
Overall im happy with it all though i did lose to a civic si with a 2.4 crv swap turbo but im getting the K&N today then im done with it but i do reccomend the stage 1 i love it
Probably stupid question does anywhere here a squeek noise from 2nd to 3rd almost sounds like a belt? im pretty sure its not tires?
Old Jul 28, 2010 | 03:53 PM
  #105
buellfooll's Avatar
Originally Posted by Bolted-N-LoweredSS
problems I had...
If you mean the noise when you let off the gas real quick to shift at boost? Normal. It's excess boost pressure blowing past the bypass valve when the throttle body butterfly closes instantly.
Old Jul 28, 2010 | 03:55 PM
  #106
thats probably it extremely highpitched squeek a full boost also was told puff of black smoke comes out at nls haha glad to here the "squeek" is normal thanks!
Old Jul 28, 2010 | 04:08 PM
  #107
buellfooll's Avatar
A LOT of people worry about that noise. It really doesn't sound like it should be there. Mine sounds like a ?????????????????????? LOUD!! Check my sig. Everything that can make it louder is on there. Check this out. Sounds just like this. And is the same as my reaction the first time I heard it.
http://www.youtube.com/watch?v=D-ZBcmcje_s
Old Jul 28, 2010 | 04:11 PM
  #108
^^ exactly sounds like a belt squeek and only under full boost shifting at redline thanks so much for the information about that!
Old Jul 30, 2010 | 07:13 PM
  #109
DoMiStIc_RuSh_06's Avatar
heres a vid of the kn intake with the flutter
Old Jul 30, 2010 | 07:30 PM
  #110
efactor's Avatar
I like that one at :12 sec. Sounds like car is going into warp speed from Captain Kirk's Enterprise in Star Trek. Awesome
Old Jul 30, 2010 | 07:35 PM
  #111
its not awesome because my poor lnf is gonna die
Old Jul 30, 2010 | 07:36 PM
  #112
efactor's Avatar
your car is not gonna die. its just that time of the month for it to go through its puberty stage right now. all cars have them every now and then.
Old Jul 30, 2010 | 07:42 PM
  #113
yeah....Im scared to drive it honestly. I can hear a squeeling when i get to high boost, sound like an air leak but i dunno where. The intake is on tight, i re tightened the chargepipes last night. iunno
Old Jul 30, 2010 | 09:34 PM
  #114
buellfooll's Avatar
THIS is what it's SUPPOSED to sound like!
http://www.youtube.com/watch?v=s_WWAVXZyuQ
Old Jul 31, 2010 | 09:23 AM
  #115
Yeah I guess mine isn't normal now, is it? Hahaha
Old Jul 31, 2010 | 09:28 AM
  #116
efactor's Avatar
Old Aug 2, 2010 | 10:53 PM
  #117
Got my car back today, 4th turbo installed. No sign of 5lbs mode, but I have a feeling it will come back soon. I'm just really hoping this turbo holds up.
Old Aug 2, 2010 | 11:27 PM
  #118
buellfooll's Avatar
So what did they say is happening to the turbo? Inquisitive people want to know.
Old Aug 6, 2010 | 12:43 AM
  #119
"Internal bearings failing" is what my service writeup/receipt says. It definitely went into 5lbs mode on the way home from a climbing gym. Turbo isn't making any weird noises under acceleration that would indicate the bearing problem again. However it did make the fluttering blow off noise when it was in 5lbs mode.
Old Aug 9, 2010 | 03:52 PM
  #120
bump. Anybody have any ideas why GMS1 is having this 5lbs problem? Does having an aftermarket tune prevent this from happening?
Old Aug 9, 2010 | 03:57 PM
  #121
Terminator2's Avatar
The cars are going into limp mode where the ECM has detected an issue and has told the BCS to keep the WG open at all times which limits you to 5-7 psi thus limiting power output. It is a feature the ECM uses to help protect the engine in the event of a major boost leak or sensor failure.
Old Aug 9, 2010 | 11:25 PM
  #122
I was referring more to the "issue" which would cause said protective feature to kick in. Seems like a good chance that most people have the same thing causing it.
Old Aug 12, 2010 | 02:15 PM
  #123
TorqueSSter's Avatar
Question Has anyone been able to get a code when this happens ?
Mine did it today, right after filling up ( the last 2 times it occurred, as a matter of fact, were after a fillup ) , and no wire wiggling or engine restarts would bring it back to normal.
I'll see what it does on the way home, BUT if the dealer could actually catch it in the act & pull a code/codes then perhaps we might be on a way to a permanent solution.
Or, not - who the hell knows.
Britt
Old Aug 12, 2010 | 02:24 PM
  #124
Cobalt_Daddy's Avatar
lol 4th turbo? maybe they should check your cooling oil feed lines?
Old Aug 12, 2010 | 09:39 PM
  #125
I believe, and this is only speculation, that my charge pipes being busted/very loose caused my turbos to start turning south. The charge pipe wasn't fixed until during the 3rd turbo, so I'm just now running a turbo with solid charge pipes. I mentioned in my earlier post about my first dealer messing up a TSB and breaking the mounts for the charge pipe.
