EXEDY Hyper Single install!!!!!!!!!!!!
Old Jun 5, 2009 | 10:21 AM
  #76
Cefaln452's Avatar
click
Old Jun 5, 2009 | 01:07 PM
  #77
Maven's Avatar
With a lift and all the proper tools it takes me about 6hrs, just a hair under 5hrs if I have no interuptions and am working fast. Its at least 8-10 hrs for most mechanically skilled people, lots of guys take two days to do it, Ive heard of several 3 day horror stories. We didnt take enough pics for a howto.....maybe if I do another one anytime soon. Pics cost more though because it takes me longer, LOL.
Old Jun 5, 2009 | 05:18 PM
  #78
~Mike~'s Avatar
I'd come out there and see if you could do it, but jersey is a long ways away from me lol Guess I gotta find a local to do it for me cuz i'm not breakin anything
Old Sep 21, 2009 | 04:07 PM
  #79
wantedSS/TC's Avatar
bumpidy bump for my clutch slip. This will be ordered shortly. Any good mechanics in south eastern PA anyone can recommend?
Hint hint - Maven?!
Old Sep 21, 2009 | 05:18 PM
  #80
oopsitouchedmyself's Avatar
hmm..i wanna get a clutch, but i think i am gonna wait till next spring.. and i'll install a LSD when i do it also.
Old Sep 21, 2009 | 06:26 PM
  #81
MaxVQ35DE's Avatar
Ok I got my flywheel bolts, slave cyl/throwout bearing, and wierd pipe thingy that Tom recommended to prevent future leakage. I found a dealership with a tech with lots of cobalt transmission experience. Now the question is should i do some billet reverse mounts to prevent excess wheel hop. I really dont experience hop unless im on really bad road and WOT. If the road is smooth , no hop to speak of.
What do you guys think?
Old Sep 22, 2009 | 09:12 PM
  #82
MaxVQ35DE's Avatar
Also, did you have to do a clutch relearn?
Old Sep 26, 2009 | 05:12 PM
  #83
tlake84's Avatar
Originally Posted by Maven
This past weekend I did an install for Exedy USA.
They wanted to verify if the LSJ Hyper Single clutch/flywheel would work on the LNF.
Well............ IT DOES WORK.
Install was smooth, all the clearances and throws are within acceptable spec, and no problems were encountered during install or in the test vehicles road test.
Dont take my word for it though, I am sure the tester will chime in soon, it was installed on Steddy2112's car.
So, call up Tom at Crate Engine Depot and tell him you need a clutch slave cylinder and 8 flywheel bolts, then call Josh or Sean at OTTPerformance and tell 'em you need a Hyper Single.
I may have done the work but you guys need to thank John at Powell Race Shop and Evan and Bernie at ExedyUSA for getting this done.
Why do you need another clutch slave cylinder? Does it take a different style other than stock to get it to work properly?
Old Sep 26, 2009 | 05:18 PM
  #84
Scythe_Snake's Avatar
subbing for when i wanna get this!
Old Sep 26, 2009 | 08:17 PM
  #85
Stamina's Avatar
Originally Posted by BartSS
How much hp and tq can it hold?
Not sure why this question went unanswered for so long... it's the second post..
Anyway, after digging around through Exedy's documents I found that this clutch has a rating of 368lbs-ft.
Exedy Part#: GH028D
Old Sep 26, 2009 | 08:24 PM
  #86
steddy2112's Avatar
Get the stage II OTTP rotated mounts and call it a day
No.
A new stock one.
More of a 'do it while you're there' because you have to take everything apart in order to do it.
Last edited by steddy2112; Sep 26, 2009 at 08:24 PM. Reason: Automerged Doublepost
Old Sep 30, 2009 | 09:58 PM
  #87
tlake84's Avatar
Originally Posted by steddy2112
Better than the stock garbage.
The pedal is stiffer, but engagement and drivability are WAAAAY better.
At which point does the pedal start to engage and can you still NLS with it as easily as the stocker??
Old Sep 30, 2009 | 10:01 PM
  #88
Black SS/SC 06's Avatar
And it had to be purple
Old Sep 30, 2009 | 10:02 PM
  #89
TurboTechRacing's Avatar
Exedy Part#: GH028D
You mean GH02SD
Old Sep 30, 2009 | 10:11 PM
  #90
tlake84's Avatar
368 ft. lbs seem really a bit on the low side for an LNF... kind of a gamble really...
Old Oct 2, 2009 | 07:03 PM
  #91
MaxVQ35DE's Avatar
Put my order in for Exedy Hypersingle and Stage II rotated mounts. The guys at OTT made me feel at ease as far as the the exedys limits. The time attack car had a nitrous shot that gave the motor at least 350lb feet. They also have some customers with 400whp and over 350lbft turbo LSJ's with the exedy.
Old Oct 4, 2009 | 09:33 PM
  #92
IsItFast?'s Avatar
whereas the stock TC clutch will make a 30 year stick veteran look like he is taking his driving test, rollin on ecstasy
I laughed my ass off on this, because after 12 years of driving nothing but stick cars and trucks (owned 13 of them now) this one can still give me trouble, and I still stall it every now and again >
Originally Posted by ~Mike~
I haven't looked yet, but maybe a how-to on how to do this particular install?
http://www.gmperformancedivision.com...SJ_Chap5&6.pdf
Hands down GET THEM. Period.
Exedy Part#: GH028D
so i checked the page and nobody answered it...what's the HP rating on the hyper single? I saw someone say that there's guys runnin it with high HP, but what is that "high HP"?
Torque is what makes clutches slip.
Exedy says 'generally twice as much as stock' on their website
From the documentation Excedy gives with their clutch, the max is 345 lb/ft. I hope this is conservative, because most of us will have much more than that.
Old Oct 10, 2009 | 11:02 AM
  #93
08SStc's Avatar
does anyone with the exedy clutch/lightweight flywheel notice a difference in idle or spool time?
Old Oct 10, 2009 | 11:04 AM
  #94
steddy2112's Avatar
What's spool time?
The stock turbo has next to none.
If you have to wait for the turbo to spool up, down shift you're in the wrong gear.
Car spins up faster with the lighter flywheel.
Old Oct 10, 2009 | 11:08 AM
  #95
08SStc's Avatar
haha, just checking, i figured that be the case, especially with the stock turbo. I and someothers where discussing this in another thread. thanx for confirming this for me. Cant wait till spring now, this clutch/flywheel combo is goin on my car.
Old Oct 12, 2009 | 11:38 PM
  #96
Squintz's Avatar
Originally Posted by 06_SIC_SS
lol where do u find this ****..
4chan's a good start
Old Oct 13, 2009 | 10:29 AM
  #97
julius41282's Avatar
Just to get this confirmed...besides buying the clutch/flywheel combo, 8 flywheels bolts, new slave cylinder, and new throwout bearing...is there anything else that needs to be purchased for this install to be done right the first time?
Old Oct 13, 2009 | 10:36 AM
  #98
Stamina's Avatar
I was talking with OTTP about this and they said that slave cylinder and throwout bearing weren't that needed if you've still got lower mileage (I made sure to ask about this several times). He did a clutch swap on his LSJ, keeping the stock cylinder and bearing, and had no issues with it.
With the clutch I bought recently, the documentation says to change out the flywheel bolts after they've been removed and reused several times.
You can't beat new stuff, but from what I'm hearing it's sounding like it might be overkill. How about calling up CED? Sure they sell the stuff and would therefore be biased, but they could probably give you some good info too.
Old Oct 13, 2009 | 10:49 AM
  #99
steddy2112's Avatar
Never reuse flywheel bolts.
Dropping the engine cradle again to change them after one comes lose and eviscerates everything in front of the firewall sounds like it may be the least of your worries...but hey you save 15 bucks.
Throw out bearing...pfft, **** it, if it fails it is just the trans.
Seriously, you are already paying a grand for a clutch/pressure plate/flywheels.
What is another hundred bux?
'Can't' afford it and wanting the eBay intake to go with your leetsos are two different things.
Old Oct 13, 2009 | 10:51 AM
  #100
Stamina's Avatar
I agree personally. I'm just stating what I've been told to see what you all think/find out about that.
Like I said, you can't beat new stuff.
