F*ck me... p0299 underboost
Old May 13, 2013 | 09:35 PM
damastah's Avatar
threw the tune on a week ago. was racing my buddies 911 turbo from harrisburg ~ baltimore. about an hour of racing. first race we got up to about ~160 and car ran fine.
then second race i was at the top of 4th and BOV went off... couldn't boost over 1psi lol....
checked all the camps. they look good. will be doing a boost leak test tomorrow. doubt i will see anything. but what i am curious is that on 14~15psi i can go up to 140 no problem. now when i go to 120 boost cuts out... i tried twice on my way home today, i could not hit 140 without the boost cutting out.
what are your guys' experience on underboost problems?
Looks like P0299 applies to the wastegate.
#09-06-93-004: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator) - (Jul 21, 2009)
Subject: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator)
Models: 2008-2009 Chevrolet Cobalt, HHR
2008-2009 Pontiac Solstice GXP
2008-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
with Engine RPO LNF and LDK (Europe)
Please Refer to GMVIS
Condition
Some customers may comment that the SES light is on. Upon inspection, you may find DTC P0299 (Turbocharger Engine Underboost) or P0234 (Turbocharger Engine Overboost) set.
Cause
This condition may be caused by a mis-adjusted wastegate.
Correction
Note: The wastegate adjustment is sometimes a very fine process. When adjusting the wastegate, only small adjustments should be made. Loosen one nut at a time and only adjust the nut one turn at a time; then tighten the other nut against the shaft and test drive to verify. This may have to be performed several times to achieve the desired boost level. To ensure proper adjustment, the vehicle should be at full operating temperature when testing. The vehicle will be very hot and may need to cool between adjustments. Too large of an adjustment can cause repeat DTCs.
Adjust the turbocharger wastegate. Refer to Turbocharger Wastegate Actuator Adjustment in SI.
Troubleshooting Tips for DTC P0299 - Turbocharger Engine Underboost
To increase boost, adjust the nuts (in) towards the actuator; in essence making the shaft shorter.
Troubleshooting Tips for DTC P0234 - Turbocharger Engine Overboost
To reduce boost, adjust the nuts (out) towards the end of the shaft; in essence making the shaft longer.
__________________
Old May 13, 2013 | 10:01 PM
AARON-SS-TC's Avatar
I think its all of the turbo-xs stuff you got thats causing the problems....lol, jk
sorry about your troubles man, i am sure it is something simple to fix.
Old May 13, 2013 | 10:30 PM
damastah's Avatar
yeah what's crazy is i had all the bolt ons before i retuned it...
i had the bov and catless exhaust and no CEL... but once i throw the tune on i have no boost.. strange
Old May 13, 2013 | 10:36 PM
GoodLuckBro's Avatar
It was probably the e-brake slides in the grass you were doing. I told you to cut that **** out.. Hahaha
Old May 13, 2013 | 11:10 PM
damastah's Avatar
lol... you never said ****... you probably only thought that because that was the most excitement your gf had all weekend lol.
Old May 13, 2013 | 11:32 PM
That was probably the most excitement you had all weekend since you got turn down by numerous girls already that weekend You wish you had my girlfriend..
Old May 13, 2013 | 11:40 PM
Kyle09TC's Avatar
check your intercooler end tanks. my friend just got that code and he had a crack on the right side tank right after we did a little highway pull
Old May 14, 2013 | 09:32 AM
Terminator2's Avatar
If desired boost is set too high to fast and underboost is not disabled in the tune it will cause this issue. Also a boost leak but normally you have a p0101 and a rich code bank 1 to go along. Wg rod could have come loose or the boost solenoid could be malfunctioning.
Old May 14, 2013 | 09:54 AM
turbosmart4's Avatar
Tommytwincams would like the title lol
Old May 14, 2013 | 04:16 PM
damastah's Avatar
yeah. i've had a boost leak before. and i know the codes that threw. although a boost leak could be the issue of this, i doubt it.
i'm thinking the wg could have came looks and maybe it's not lookse enough at low boost to set off a code.
Old May 17, 2013 | 07:33 PM
damastah's Avatar
just did a legit smoke boost leak test... started on one side of charge pipe where turbo is. closed the TB and put the fog machine on it until it started coming out on the side that was open... nothing... no fog...
i'm pretty upset now. lol... i was honestly hoping for a crack in my FMIC or a loose clamp lol... this sucks
**** the WG
Old May 17, 2013 | 07:52 PM
It's probably from you beating the **** out of your car
Old May 17, 2013 | 08:01 PM
damastah's Avatar
i take good care of my car so there is nothing wrong with beating on it... i don't do anything stupid other than rev past into redline once every 6 months lol...
Old May 23, 2013 | 11:29 AM
ctn2mb's Avatar
When I had this... dealer replaced the turbo.
Jekyl
Canadian Mid West
Sep 6, 2006 01:21 AM
mike25
Wheels and Tires
24
Jun 21, 2006 11:00 AM
undrgrndcobalt
Mar 23, 2006 02:53 AM
ybnormal07
Dec 6, 2005 07:25 AM
MacG321
Dec 1, 2005 12:48 AM
