first ss t/c with cams
Old Aug 21, 2009 | 10:36 AM
pookie025's Avatar
local shop forced induction motor sports told me he can send out my cams and some place will gring them down or really not sure what they would do to them, but pretty much make the cams to add alot of horse. he said ill most likely be the first with them for the t/c. any opionons
Old Aug 21, 2009 | 10:39 AM
CudaJoe's Avatar
after you get them on, make a post. Im interested in any saftey concerns for the motor with a grinded cam. also would like to see the power you make
Old Aug 21, 2009 | 10:44 AM
steddy2112's Avatar
Why get cams when the stock turbo can only flow so much air?
Old Aug 21, 2009 | 10:45 AM
Shez's Avatar
sub'd.
Mazdaboi318's Avatar
subbdddd
Old Aug 21, 2009 | 10:52 AM
CudaJoe's Avatar
thats a good point but if the cams flow better, than the turbo will flow better as well. The turbo is has a spool limit but is also limited by the cams that feed the air into engine.
Theoretically if you get better flowing cams then you should be able to have a free-er flowing turbo and a better flowing turbo until the spool limits the air flow. So I fore see a power increase in the mid-high rpms. maybe more power after 5100rpms, thats would rock.
Old Aug 21, 2009 | 10:55 AM
1badBlueberrySC's Avatar
THe turbo will ONLY flow so much air.... so doing these cams won't do ****. THe cams are NOT our cars problem...
The head is our problem... so your going to be trying to CRAM 10lbs of **** into a 4lb bag.... good luck with that!
Old Aug 21, 2009 | 10:56 AM
steddy2112's Avatar
MMMMmmmmm
More heat.
Sign me up
Old Aug 21, 2009 | 10:58 AM
Can't wait for this!
Old Aug 21, 2009 | 11:12 AM
CudaJoe's Avatar
true, i forgot about that head! if you get the cams in your car, port your head and match the intake manifold!
Old Aug 21, 2009 | 11:26 AM
pookie025's Avatar
this will be after a turbo upgrade, thanks for explaining that its better for a bigger turbo. any ways its gonna be 300 per cam
Old Aug 21, 2009 | 11:29 AM
FutureEcotecOwner's Avatar
Ported head > grinded cams
Old Aug 21, 2009 | 11:35 AM
Terminator2's Avatar
X2. The intake ports on this head flow like crap. The flow less air than and LSJ head.
Old Aug 21, 2009 | 11:38 AM
agent007kimball's Avatar
I agree that it seems like the turbo and head need to be worked over first in order for this to be an effective upgrade, but interesting to hear about nonetheless....keep us posted.
Old Aug 21, 2009 | 11:52 AM
northvibe's Avatar
Theres someone on the lnf-performance forum trying to cams too.. I agree though, not until the fueling tables are unlocked, you have a upgraded turbo and new head will you need cams. which is what well over 450whp and up.
FLOWS like pooopie
Old Aug 21, 2009 | 12:10 PM
Tofu's Avatar
Is there any place other than the dealership that sells LNF cylinder heads?
Old Aug 21, 2009 | 12:12 PM
I know someone with a few of them!
Old Aug 21, 2009 | 12:14 PM
Tofu's Avatar
I have a contact for LMR performance here who does their CNC work. He ported my LS6 heads when I had my LSX, did incredible work and provided me all the flow benchmarks as well. It would be cool to have him take a stab at the LNF head.
Old Aug 21, 2009 | 12:15 PM
dunit121's Avatar
sub;d
Old Aug 21, 2009 | 12:16 PM
06blackg85ss's Avatar
things in order you need to worry about, stock turbo, fueling is the biggest issue , then head flow then cams
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
