Flex Pipe on the Downpipe
Old Nov 23, 2009 | 12:17 PM
reign1's Avatar
OK so i am working with a company thats aking a new DP thats coming out. 3 in catless as it should be.
But they decided to not put a flex pipe in there. Just straight flange then pipe.
Iasked why they did this and they said flex pipe makes you lose HP. but now im curious because I dont want to crack welds or Bolts because I know the motor moves.
Discuss?
Old Nov 23, 2009 | 12:18 PM
slowbalt84's Avatar
good luck lol
Old Nov 23, 2009 | 12:23 PM
BartSS's Avatar
^^^^ what he said
Old Nov 23, 2009 | 12:24 PM
glen229's Avatar
lose hp lol not at all
Old Nov 23, 2009 | 12:27 PM
reign1's Avatar
lol yeah luckily they are making their DP just like my Catless DP (3 in catless DP WITH flex pipe)
and Ill switch it out so I can run their 3In Exhaust with my DP.
Old Nov 23, 2009 | 12:43 PM
Gimpster's Avatar
If you've ever fabricated many exhaust parts, you know why the flex is there. Keeps everything from rattling & reduces the possibility of cracking and metal fatigue in general. Even with solid mounts a motor rocks back/forth quite a bit during hard pulls. For a street duty car I'd be hard pressed not to use one.
A GOOD QUALITY flex isn't cheap, so there are financial reasons why a shop might not opt to use one. The performance angle of it would be really minimal if hardly measurable.
Old Nov 23, 2009 | 01:12 PM
reign1's Avatar
shop is pretty big im not just naming the company.lol
Old Nov 23, 2009 | 01:22 PM
ddsscobalt's Avatar
yea that flex section is for the motor movement... motor is gonna move no matter what mounts you have.. ***** gonna break homie
Old Nov 23, 2009 | 01:39 PM
TurboTechRacing's Avatar
Agreed
You should really have a flex as stated here, they are not cheap, but well worth it. It should be a good flex also, otherwise the flex itself will fail.
Also agreed.
Mounts will help, but will not be enough to remove/forget about having a flex.
A company should not cheap out to have a better apealing price and not put a flex in, they (the company) will most likely have many product failures.
Last edited by TurboTechRacing; Nov 23, 2009 at 01:41 PM. Reason: Automerged Doublepost
Old Nov 23, 2009 | 01:40 PM
glen229's Avatar
yes, get the Turbo specific interlocking flex pipes
Old Nov 23, 2009 | 03:12 PM
reign1's Avatar
understood. ill recomend it to them.,
just wanted to double check
Old Nov 24, 2009 | 06:58 AM
oopsitouchedmyself's Avatar
i find it hard to believe a reputable large company would need to have any advice on whether or not to use a flex pipe.. i'm not saying i don't believe this is what they've told you, i'm saying what most other ppl here have said, it's not right. a good company would be more interested in doing things correct..
Old Nov 24, 2009 | 07:05 AM
Originally Posted by oopsitouchedmyself
i find it hard to believe a reputable large company would need to have any advice on whether or not to use a flex pipe.. I'm not saying i don't believe this is what they've told you, i'm saying what most other ppl here have said, it's not right. A good company would be more interested in doing things correct..
x2...
Old Nov 24, 2009 | 12:11 PM
BYT*SS*TURBO's Avatar
Moving the flex piece I would be a fan of. I never liked how the Flex was RIGHT at the turbo. Altho it seems to work well, just something that rubbed me wrong from day 1 honestly.
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
