forge BPV problem/turbo flutter??
Old Jun 6, 2012 | 11:17 PM
ss slobalt's Avatar
so just got my BPV in the mail and installed. I love it sounds amazing!! PROBLEM IS my first initial drive from when it hasn't been ran or random spurts of drivin it makes a whipple kind of noise and I can't tell if it's turbo flutter or not? any ideas?? it's usually around 3K RPM or so not to sure how much boost when it makes the noise. I've tried both springs. does it most with the yellow I'm tuned running 22PSI. thanks guys!!
Old Jun 7, 2012 | 03:22 AM
LNFwagonSS's Avatar
The valve has a flat spot on one of the three sides. Which way is it mounted? Mine installed with flat spot pointing down towards front of car. I experience minimal "flutter" in certain conditions.
Old Jun 7, 2012 | 07:10 AM
CudaJoe's Avatar
Basically when you installed it, does the opening face down? When the piston compresses which way will the air try to escape? up or down. Simple way to figure that out is take the thing off and psuh the piston in and see which way it opens up. You probably have it upside down.
Old Jun 7, 2012 | 10:48 AM
vahdyx's Avatar
I wouldn't use the yellow spring.
But like everyone says, opening down.
Old Jun 7, 2012 | 01:11 PM
ss slobalt's Avatar
holy crap I'm an idiot I was thinking opening with the air tube that recirculates the air no the piston opening. I feel like such a ******* right now hahah ok let me go chek and see and I'll post an update when I get to it thanks guys!!
Old Jun 8, 2012 | 05:48 AM
Sloco Productions's Avatar
also make sure the top peice is all the way tight...mine was on there crooked and fluttered....quick fix
Old Jun 8, 2012 | 07:18 AM
CudaJoe's Avatar
pfffff, you didnt hook up that vac line did you. The recirculation occurs within the turbo. If you take out that BPV and look you will see the compressor housing is channeled back into the turbo inlet. The BPV acts as the door for that to happen.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Sep 27, 2015 08:53 PM
