GM Stage 1 Issues !!
Old Aug 17, 2012 | 09:47 AM
QuickSilver_SS's Avatar
SO i just got my GM stage one kit installed yesterday. And I love the extra power and torque. But im having two issues already. One , every time I go wot in second gear my tires break loose and spin the rest of 2nd. Secondly , that purge valve solenoid on the intake mani keeps blowing the line off everytime I go wot. It looks to me like the clip that holds it on is all bent and twisted. Its pretty loose and isnt holding . So I may have to zip tie it. Does that sound ok to do ? Other then that. I love the extra grunt and pick up !
Old Aug 17, 2012 | 02:17 PM
Anyone else ever try to replace the clip in the purge solenoid line.? It seems to be part of the line? But I can't tell totally.
Old Aug 17, 2012 | 02:27 PM
serega12's Avatar
Did you install it yourself or did you have a dealer/mechanic do that for you? If latter, take it back and have them fix it... If not, be careful with plastic zip ties so close to the manifold. trim the ends if you do unless you like the smell of melted plastic.
Old Aug 17, 2012 | 02:29 PM
I didn't think there was much heat there. !!!
Old Aug 17, 2012 | 02:30 PM
Cobe's Avatar
X2 on that ^^ lol and you need to learn to feather your car through second gear... Spinning is normal.. What I do is when I slam second I seem to spin then I catch.. Then I start to spin again... To keep my self from spinning the second time I let off the gas 25% and then hammer it again real fast... Lots of practice but you will get faster at it!
Old Aug 17, 2012 | 02:36 PM
serega12's Avatar
Oh, was thinking of a diff sensor then right next to the exhaust manifold. I stand corrected.
Old Aug 17, 2012 | 02:44 PM
klotzy_550's Avatar
If the dealer is at fault and broke the clip then its their bad. If you caused it, then just replace it with a piece of hose, that is what I did when I installed the blower on my 2.4. I figure it has the same style of barb on each end, correct me if i'm wrong, so you should be able to put some vacuume hose in there.
Old Aug 19, 2012 | 01:22 AM
jmiller15's Avatar
Breaking loose is pretty common I'd say, it happened to me on gms1 and it happens to me on trifecta, good tires are your best friend!
Old Aug 19, 2012 | 02:06 AM
Aleksey's Avatar
235 tires here and I don't lose traction at all..
well fine okay I do in high boost but only over 15PSI, still minimal loss though
Old Aug 19, 2012 | 03:43 PM
09TcSedan's Avatar
OP,are you on stock contis?
i have GMS1 and only on cooler days (50-65 degrees) i can spin in 2nd gear.
i have kumho ecsta's. they grip and rip,not the best tires but they were brand new when i bought my cobalt.
Old Aug 20, 2012 | 03:41 PM
No, I'm on a set of sun full tires. There definitely not the greatest tire out there. But there nit to bad surprisingly enough.
Old Aug 20, 2012 | 04:05 PM
BlackLsCoupe's Avatar
get better tires. GMS1 and stock size tires with my BFG's little spin
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
