GM Stage 1 and Muffler Delete
New to the forum.....hello.
So, i had the gm stage 1 installed on my 2010 turbo by the dealership. It ran awesome but sounded wimpy, so i decided to delete the muffler.
now two weeks later it went from spinning tires in second and running rich, to slow and and running lean. i took it to the dealership and they are trying to say its because " Lack of backpressure"....
Edit" it hasnt lost any boost pressure either "
Has anyone else had this issue>?
Thanks
ohhh and no codes/cels
Thanks
Better idea...if they keep giving you a hard time...put the muffler back on and prove that it still doesn't work. Nothing better than throwing a dealer's lies in its face.
Muffler Delete will not change a damn thing on this car (outside of sound). And that's that.
yeah if thats what i have to do i will, but i was just making sure.
i was already having a shuddering issues when it was cold, under no load and low rpms, before the muff delete and i told him that. its obviously the install on the kit.
they did the solder and heat shrink and bend the ac tube and blah blah blah......
They still couldn't figure out my skewed and random rich to lean a/f ratio????
ANy ideas? O2 sensor, bad 3 bar map sensor,????
so now i have to put the muffler back on and bring back in.
its driving me crazy, it only has 800miles on it and it went from being fast to stock feeling. it only happens when the car warms up to operating temp 180-190. i sware im going to have to lemon law this **** if they dont fix it.
Agreed. I think it was Hahn that flow-benched all the exhaust components a while back and found the muffler flowed roughly twice as much as the cat, and much more than what the stock turbo could theoretically produce. Since the cat is still in there, I can't see how taking out the muffler could make a damn bit of difference.
