Goodies came in the mail...but...
Old May 6, 2010 | 10:28 AM
  #176
Sweetsandman's Avatar
Originally Posted by JPizzle
Yep. Just wait on the stronger spring... I'm sorry that you had to go through all of this man. I just wish I could have helped you, and told you you needed the stronger spring... But I didn't know because it was a Tial.
Nah no biggie I wouldn't have known what I was doing anyways lol. There were no options for different springs through ZZP's website it just says "All units are tested for leakage and proper opening at 18-20" vacuum"...and since that's what my vacuum was sitting at before this mod I assumed that was the correct thing to order...Not sure why my Vacuum readings would have changed from before and after this mod but apparently they have...
Old May 6, 2010 | 10:31 AM
  #177
Negrita SS's Avatar
Sorry dud I thought you had the stronger spring but happy that we got it figured out
go to this web site http://www.tialsport.com/products.htm
  #178
^^Yes and maybe someday I will actually like my BOV lol. But seriously...can anyone think of any reasons why before doing this mod I was seeing between 18-20 vacuum at idle and now I'm seeing 20-22 afterward? For some reason that doesn't make sense to me??
Old May 6, 2010 | 11:27 AM
  #179
Matt M's Avatar
That doesn't really make sense, but if you are over 20" at idle, then you will need a stronger spring. Mine is only around 18, but the tune is completely different, so anything is possible. I think I will just send you a different BOV so you don't have to take it apart.
Old May 6, 2010 | 11:41 AM
  #180
OK cool! Simple enough...do you think that MAF code has anything to do with the Vacuum not being where it should?
OK...did a little test...cleared the code and now my Vacuum is sitting at about 19-20 Vacuum...??? But the BOV is still leaking at idle...maybe it's just a bad BOV or spring or something??
Last edited by Sweetsandman; May 6, 2010 at 11:41 AM. Reason: Automerged Doublepost
Old May 6, 2010 | 12:36 PM
  #181
Supercharged Guy's Avatar
Dammit I ordered the same bov that Sweetsandman did and mine comes in monday and hes having problems with the spring.
I guess I might need a EXPERT to come install mine if there's a problem with his, or I might need the bigger spring
I got the stattama 50mm bov that is way cheaper then the real Tial but will the bigger spring fit into it I'm sure it will but want a deff. answer
Old May 6, 2010 | 12:41 PM
  #182
Matt M's Avatar
The BOV is fine. You are just pulling too much vacuum to use that valve.
We will swap yours, too. I will make sure we only use 21" vac valves on LNFs from now on. We never had this issue before because most people only run them with a blow-through MAF. In that case, a tiny leak because the valve is open just a hair wouldn't matter. The MAF would still read fine.
Old May 6, 2010 | 12:53 PM
  #183
Interesting so when I do the MAF relocate from you guys later on down the line (next mod for sure) It won't matter if the BOV is leaking a bit like it is currently? Obviously the leak will be fixed by then, but just for reference.
Old May 6, 2010 | 12:59 PM
  #184
Matt M's Avatar
Sandman- your 21" valve just shipped. There is a return label in the box. If you could put the old valve in this box and stick the label on it, you can give it to the UPS driver.
Right. You still want it closed all the way at idle/cruising, but it wouldn't hurt the tune at all on a blow-through MAF setup if it was open a little.
If you haven't inatalled yours yet, we should wait to see how sandman's works out and I can get a new valve sent your way tomorrow.
Old May 6, 2010 | 01:25 PM
  #185
Will do! I live right by the UPS store so I'll run it up there as soon as I get out of work tomorrow. And I received the spacer today as well! It's not what I was initially expecting but I see how it works. Just for reference to anyone else that requested the block off spacer since I was probably the first to receive it and most were probably expecting what I was expecting. This is what you sent me:
But I was expecting something like this for some reason:
I'm taking it that that piece of piping just replaces the spring that is in the factory BPV.
Old May 6, 2010 | 01:32 PM
  #186
Yah lol okay I just dont want to have a problem like Sweetsandman did I want to try and avoid all the troubles he is going through
How does that piece block off the stock bpv? that looks weird, but I'm sure it works
No I havent installed mine yet so if you would like you can send me a bigger spring that would be awesome. Thanks Matt
Last edited by Supercharged Guy; May 6, 2010 at 01:32 PM. Reason: Automerged Doublepost
Old May 6, 2010 | 01:33 PM
  #187
It doesn't "block it off" in the sense that I was expecting like the thing from Hahn does. But with this, you take out the spring from the factory BPV and replace it with this solid pipe...thus, disabling the factory BPV if I'm not mistaken.
Old May 6, 2010 | 02:38 PM
  #188
Oh okay, I was thinking that the stock bpv needed a block off plate like the hahn one above, but I guess not
Old May 6, 2010 | 02:41 PM
  #189
See I knew other people were expecting what I was expecting Either way works fine though, as long as you essentially disable the factory BPV all should be well.
Old May 6, 2010 | 02:42 PM
  #190
Matt M's Avatar
You are correct. It holds the valve closed. The Hahn plate hold the valve closed as well. It just replaces the cover. If the turbo was visible on the car, I can see where theres would look nice, but since you can't, we use these and save you $40.
Old May 6, 2010 | 02:55 PM
  #191
Hey I'm all about saving money lol we all are, as long as it works I'm good and I'm sure it will
Old May 6, 2010 | 03:15 PM
  #192
crypticscifer's Avatar
Didn't Hahn make two revisions of that piece?
Old May 6, 2010 | 03:54 PM
  #193
It wouldnt surprise me they are the first for everything like Intake, Exhaust, etc. but they are also the first to revise everything
Old May 6, 2010 | 06:42 PM
  #194
LOL they don't believe in the "measure it twice cut it once" philosophy I guess.
Old May 6, 2010 | 07:48 PM
  #195
^ Yeah I guess not haha but when my bov comes in is there anything that I should do/know so that I dont run into problems or **** it up?
lol I know the problem's you had and I'm sure it was just the spring, thats what everybody came to agree on
but I'm curious to know how much better it will run with the bigger srping in it cause Matt said he would wait for your response before sending me 1
Old May 6, 2010 | 08:40 PM
  #196
I'll update as soon as I install it tomorrow don't worry. And the only problems I ran into (outside of the BOV) were getting the new Charge pipe onto the lower rubber tube. It's a TIGHT squeeze and there's not a lot of room to work with down there. And getting the lower clamp off that was holding the factory charge tube on. It was a pain in the butt trying to cut it in that tiny area...then I busted out the dremel and got it off in 2 seconds...so hopefully you have a dremel...because a razor knife or saw will be able to do it...but it will take forever and make you want to kill yourself.
  #197
02RedWS6TA's Avatar
Just an update on my parts. I got my new CP today and everything went great. I'm not sure if the car is stronger since I only had my Trifecta tune for a week and then the DP/CP went on. I'm hoping to hit the track sunday morning before any mothers day activity so hopefully I will have some times sunday afternoon.
Old May 7, 2010 | 08:26 AM
  #198
Lmao, Okay yeah I'm sure I have a dremel to cut it off so I'm not worried and I did look down there the other day
your right that is very tight down there but I'll figure it out I might try underneath and see if I can do it better that way
Old May 7, 2010 | 09:17 AM
  #199
Trust me...underneath won't work..unless you want to take a lot of **** off to get to it. From up top it was relatively simple...you just have to have a good grip and use a lot of force to shove the new pipe on there...and a dremel...I can't stress how much simpler having that made everything.
Old May 7, 2010 | 10:14 AM
  #200
SSlobalt's Avatar
It takes about 5 minutes to pull the wheel well out of these cars and it makes access to all that stuff a snap.
