GT3076R Kit Complete
will be once Bill gets it out to me. I think these motors will make some retarded power once fueling is resolved. Adjustable cam timing ftw, can't wait to really wring this sucker out. Just another NY cobalt shooting for 11's this year.
At least we aren't trapped at 345whp (give or take a few) like the MS3's are lol.
hes blowing the k04 into the inlet of the gt40 but if he blew into the exhaust housing OMFG!! wonder what would happen lol
outlet k04 pressure into exhaust gt40 housing + ratio to compressor of gt40 could cut spooling close to half if the k04 turbine side will flow it otherwise hes fucked has to keep it how it is.
Has anyone tried to talk to Vince at trifecta about this? He is pretty good at cracking **** like that.
So extra injectors it may be for now. or reworking the stockers.
I talked to vince about this he said he was going to look into it but that makes sense as he didn't think the stock injectors should be running out of flow .. but he didn't have any definite specs on the injectors so he coudlnt' be certain
If i get an updates about it i'll let you guys know
yea but after so much pressure these babies wont open or will open slowly. ford for example even though its deisel the di is the same. the injector is opening with an aid of oil pressure. the solenoid controls the flow of oil in the injector to cause an opening and closing. ours have no pressurized oil source to help with opening, we rely on the coil solely. dont know when they will stay closed just know at a certain pressure they will start to suck. find out soon though with whoever releases first vince or hpt.
compound setup hmm i will look this up, thanks
On top of the DI. The extra injectors inject only whan you are the upper revs at WOT. They will need a secondary stand alone fuel management system though. It would be better if someone makes Higher flow DI injectors. Stockers are 122lbs/hr but have only half the amount of time to inject as a typical port injector so they are in reality like a 60lb/hr injector so they support only around 400 whp.
Last edited by Terminator2; May 2, 2009 at 12:05 PM. Reason: Automerged Doublepost
I can only hope so! And to be honest, I have NEVER been on a strip
, but I'm sure I would pick up on it pretty quick. I would say low 12's, high 11's if I can drive good
Hey, it's made to bolt up to factory parts for a reason bud!! So you can take it off if something like that were to happen and it needed warranty work done!
And, Hahns car ran 13 flat... not 12.9 >>> he red-lighted and that is not added to the time.....
Your car would run 11's on slicks...... I'd say 11.8
Even the kit that's listed by baldturbofreak does not list a fuel pump upgrade and it NEEDS TO!!!!!!
Anytime you add 100+ more wheel hp to ANY CAR, it will require a fuel pump upgrade or it will not run right....Garanteed......
