GT3076R Kit Complete
Old May 4, 2009 | 04:56 PM
  #276
elecblue06's Avatar
Originally Posted by SportredSS
8 hrs and $600 later it'll come out ya....!!!!!
And, Hahns car ran 13 flat... not 12.9 >>> he red-lighted and that is not deducted from the time.....
Your car would run 11's on slicks...... I'd say 11.8
I do hope you have a walbro 190 or 255 fuel pump in the tank too? these cars will not run right and hit fuel starvation due to not a big enough fuel pump before they have issues with fuel delivery under the hood... I've seen several 5457 dejon turbo upgrades and aGT3071... and these kids have never had a car with this level of power and they've all forgotten about their fuel pump..... >>>>Tuning issues and not running right!!! because not enough fuel flow to the engine due to the fuel pump....
Even the kit that's listed by baldturbofreak does not list a fuel pump upgrade and it NEEDS TO!!!!!!
Anytime you add 100+ more wheel hp to ANY CAR, it will require a fuel pump upgrade or it will not run right....Garanteed......
FAIL
not true... these fuel pumps are fine stock.. just need access to fuel pressure tables... and no you dont need a new fuel pump when you add 100 whp to any car..
GOD DAMN you always chime in and you NEVER know wtf you're talking about
Old May 4, 2009 | 04:59 PM
  #277
crypticscifer's Avatar
Originally Posted by elecblue06
FAIL
HaHa...hahahahahha
Old May 4, 2009 | 05:00 PM
  #278
elecblue06's Avatar
Originally Posted by crypticscifer
HaHa...hahahahahha
i'm just going to assume your agreeing with me ? to make myself feel better
Old May 4, 2009 | 05:02 PM
  #279
mmcgee123's Avatar
I run a extra 100hp on stock fuel pump and it runs awsome so I think u need to lay off the pipe lol
Old May 4, 2009 | 05:04 PM
  #280
elecblue06's Avatar
exactly I run 100 whp over stock too .. there are a bunch of people that do granted i dont have an ss/tc or an ss/sc so our fuel pump is different but still
Old May 4, 2009 | 05:09 PM
  #281
BumbleBee's Avatar
yo dawg wear da vidz wear da car moovs an stuhf....
Old May 5, 2009 | 10:29 PM
  #282
FakeWhiteMan's Avatar
this
Old May 5, 2009 | 10:36 PM
  #283
BumbleBee's Avatar
Originally Posted by FakeWhiteMan
this
that
Old May 8, 2009 | 09:44 AM
  #284
revhigh18's Avatar
so what the hell are all the options on the site i want the kit i just dont know what im buying what the hell is swiantech white lightning and whats the gt35 with ported shroud? do we also need to get a block off plate and how do i fit a bov on the hahn pipes
Old May 8, 2009 | 10:55 AM
  #285
Yeah your last comment in the post was classic.
Old May 8, 2009 | 01:42 PM
  #286
Sw4y1313's Avatar
So true I was 90whp over stock and never had an issue with fuel. AND! I had an extra injector pulling from the rail with no issues.
You think I'll need a new fuel pump now? We'll wait and see how she handles 350+whp in a couple weeks.
Old May 8, 2009 | 01:45 PM
  #287
Terminator2's Avatar
I am 90+ whp over stock too but he is talking 150+ whp over stock.
DI is a different animal. More fuel demand means more pressure needed to properly atomize the fuel. Otherwise we get fuel puddling in our cylinders and that causes incomplete combustion and power loss no matter what size turbo.
Old May 8, 2009 | 01:53 PM
  #288
CudaJoe's Avatar
unburned fuel in cylinders actually helps keep the turbo/engine cooled under high boost:P
Old May 8, 2009 | 01:58 PM
  #289
It also causes the high rpms power losses in all the big turbo LNF cars. DI is not the same animal as port fuel injection it is more like a Diesel with spark plugs. All big turbo LNF make about the same amount of peak power aroud 390-400 whp because there is no way to rev them over 6500 rpms because of the fuel issue.
Old May 8, 2009 | 04:36 PM
  #290
revhigh18's Avatar
no one gonna answer my questions
Old May 8, 2009 | 06:53 PM
  #291
I would if I knew the answers. I would try contacting the respective sellers. BTF, Dejon, Synapse if you have questions on their products.
Old May 9, 2009 | 11:35 PM
  #292
Baldturbofreak's Avatar
To help put the pump concerns to bed, even at 46lbs/min the pressure in the DI rail never comes off 2150.
use your aeroforce or Dashhawk to confirm.
Revhigh 18, pm me with any questions you have. The ported shroud is mandatory when using the GT35R on our 2.0. Without it it surges like a mother above 23psi.
Swaintech Whitelightning is IMO the only coating that is worth a damn. It's not very pretty, but it IS pretty functional. It will reduce radiant heat by a significant amount.
Old May 10, 2009 | 10:24 AM
  #293
Boosted_Cobalt09's Avatar
well couldnt you use ceramic coating or dei heatwrap if your that worried about the heat?
Old May 10, 2009 | 12:30 PM
  #294
revhigh18's Avatar
ok thank you and i have to run a bov and recirculate it?
Old May 10, 2009 | 10:18 PM
  #295
you dont have to recirculate anything....its just an option. after getting this your going to need a tune so just have the car tuned for an atmospheric bov
Old May 11, 2009 | 10:00 AM
  #296
revhigh18's Avatar
dont you get underboosting issues with out it recirculating?
Old May 11, 2009 | 10:05 AM
  #297
It goes extremely rich for a few seconds after you let off and the BOV releases. Bogs like crazy.
Old May 11, 2009 | 01:56 PM
  #298
^^^^unless your tuned......if your untuned thats whats going to happen because your computer doesnt know where the air is going to. if the car gets tuned for having a bov on it then theres not going to be any issues.
Old May 11, 2009 | 02:10 PM
  #299
Nope. You cannot tune out the rich spikes without causing a lean condition at low load and idle (not safe at all to do). Recirculate back into the intake post MAF or convert to a blow through MAF setup otherwise you wil have issues eventually. Why do you think almost every menber on here has sold his BOV after owning it for a very short time.
Old Jun 28, 2010 | 10:26 AM
  #300
cobaltshawn's Avatar
So is any one have a. link to git it or look at #s how do i get this. turbo already
