GT3076R Kit Complete
how is that rice? thats a pretty biased opinion muh friend. that is one of the better BOVs on the market and HKS is pretty famous for the quality proven products they put out, maybe it's rice because it's not an american company? LMAO
Seeing how that's my car let me say that it made that same sound from the intake without the bov. So that is not related. It does sound like surge but the car doesn't make that sound under boost and backing off the throttle so who knows?... I may try snapse. Very nice design!
every ****** ricer gets that BOV because it blows off soo damn easily lol, every damn srt4 guy, and every other turbo 4 cylinder almost lol. I just hate how it sounds, and it works just as well as any other bov does.
I believe it comes with a HP Tuners Tune file, not sure though. That should help out until you can get a "real" tune.
someone buy my brand new 3 inch exhaust dump!!! this will help all you turbo guys!!, dont waste your money on a catback. Get the three inch d/p then weld the cutout onto there, or just weld a flange onto it.
yes there is an option on the site for atmospherics
there is 2 kits a full and short kit
SHORT KIT:$2299.00
Short kit includes: The kit will consist of: 1)Gt3076R 1)Tial SS housing modified for KO4 flange/VB44 1)oil feed line with restrictor for BB. 1)VB44 wastegate 1)mild steel dump pipe 1)Tial to Ko4 downpipe adapter (304L stainless) using proper Tial flange and V-band (again $$) It bears load so it must fit correctly. 1)6mm drill bit to enlarge oil drain bolt holes. This kit is for people with their own intake and BOV. it includes no coldside stuff,intake or discharge.
FULL KIT:$2550.00
The kit will consist of: 1)Gt3076R 1)Tial SS housing modified for KO4 flange/VB44 1)oil feed line with restrictor for BB. 1)VB44 wastegate 1)mild steel dump pipe 1)Tial to Ko4 downpipe adapter (304L stainless) using proper Tial flange and V-band. 1)4-3" elbow, silicone 1)3"neoprene flex section for intake 1)2.5" turbo to compressor piping stub (with recirc or BOV flange) 1)Bosch bypass valve 1)nessicary hoses and clamps. 1)6mm drill bit to enlarge oil drain bolt holes. Original heat shield fits. It re-uses the cast downpipe elbow, modifies and re-uses the intake for a nice sleeper look. It also means that no MAF transfer changes are nessicary, it will run fine even without tuning. Allowing you to safely drive it to your favorite local tuner to have it tweaked in for your car. It re-uses the coolant lines,oil drain, and hardware. They just need a little hand tweaking. The rear motor mount heat shield needs some bending to fit the rotated position of the down pipe.
AVAILABLE OPTIONS FOR FULL KIT INCLUDE:
BOV= 50MM $241, TIAL ALPHA Q $263
BOV COLORS= BLACK, BLUE, PURPLE, RED, ALUMINUM
BTF STAGE 1 BADGE $32
ALL INFORMATION FOUND DIRECTLY FROM BTF RACING
SHORT KIT:$2299.00
FULL KIT:$2550.00
You like your BOV's huh? Your the guy that blows off to people all the time or do tiny dashes with finishing touch "pshhhhhhhhh"and since you have Evo's go about thinking your the CAR. UMMMM ok. You and your buddies have fun pshhhhhhing after every gear letting everyone know. (Sigh)
PS: I owned an 04 STI so don't throw the usual JDM Hater card. Goodnight
SPLOOGEAHOLIC
and i'm pullin your a JDM hater card...
FTW!
