Guess what? Its back and worst.
well to help you guys out,
I had 0236 and 0238.
My problem was the lower sensor harness coming unplugged. With that being said, not sure sure if was the sensor or the giant boost leak that caused those codes.
I'm not very good at the mechanic stuff, but I would start at the turbo and check all piping to the intercooler and all the way to the throttle body.
Make sure all sensors are tightened down and if the dealership can't find a leak they need to rewire the lower sensor.
That's what fixed mine.
Since I moved the wires from under the AC line and zip tied them to another line running vertical I haven't had the problem again. Nothing. I mean every sign is completely gone. Ran the AC all day today on the way to work, lunch, and back home. No issues. Went through the tunnel which even seems to suffocate my car and 0 issues. I think this fixed it for good.
Got a new problem now.
I was driving on my way to visit Gestapo to some party at a recreational park. Had my 3" ZZP Catless Dp for 2 days now. My car badly backed fired and started my car to bog down like it wanted to shut off. So, I had to keep my foot on the gas to keep it from stalling out and later it enter into limp mode so I couldn't go past 5psi, and it kept back firing. No CEL. It did this for awhile, thought my car was going to die on me. After I parked, I checked under the hood, the engine sounded just normal. After I turned it off and back on, it misfired 3 times with my lights blinking inside, so I don't know what is going here. I started to follow backed to Gestapo's house my car came off of limp mode and my boost was back up, but I can't push as much as I use to. My boost went from 23psi down to 15 to 18 psi. Anyone else had this problem? I'm probably gonna go out and reset the battery and see if that get's rid of it, if not I'm going to the dealer.
That's wierd..... I know my car made a huge backfire the day my lower charge pipe blew off the throttlebody.
I'm going home this weekend where I'll have a garage to work on the car so I'm gonna try a bunch of stuff to get this issue resolved.
well I checked out the cat scan, no CEL codes. so, that was for nothing. I don't have the intake anymore. took that off and went back to airbox. I ran a couple of hard runs before work it was pushing 18psi maxed, after 5 runs I saw my boosts restored back up to 23psi.
how can a downpipe cause any problems. Theres but 1 sensor on it to check if the cats are reading properly, and right now that sensor is in an angled O2 bung fooling it into thinking everything is normal. other then that, its post wideband, so how can it cause any problems. How can it cause misfires, or reduced engine power. Its post motor, i just cant see how that can casue any of his problems.
Earl, sell it and go get an SRT-4 so youll be happy. Stop being **** n counting boost numbers. I dont even know how many psi i boost actually. I never look at the gauge. I can tell you how it feels though. And if it feels like its pulling like it should. I misfire alot, believe its the wideband going out.
Gms1 for 10,000km no issues but again i didnt **** with anything.. No dp, no intake, no chargepipes... I just dont trust the dealership with warranty and also worried even little changes in the setup will cause issues with the tune. Goodluck!
LOL
I honestly do not know one person that gripes about their car as much as you do Earl. resetting your fuel trims by your "battery" trick only works for a few minutes untill the o2 warms back up and new trims are learned.
I have had the same issues in the past by installing a make shift short ram intake and not tuning for it... car would make 2-5psi till I turned the car off and restarted it....
Find time get your ass up here with the intake on it and we'll solve these issues.
LOL
you guys would done the the same damn thing worrying about your car messing up and post forums, don't give me that crap. all my car did is back fire pretty bad, sent my car into limp mode with couple of backfires, and later it got off of limp mode, did a couple of hard runs and later things were normal.
that's because he was having issues before on the other forum when you raced him. he is a cool guy and all. I have no issues with him.
Earl, just get Dubbie to throw a nasty tune on there and you will be good to go.
Or, like me, puss out and save your warranty.
Earl just sell me your MAP sensors n go back to stock
