hahn super 20g turbo?
Old Jul 4, 2013 | 03:00 AM
  #176
ATLsilverSS's Avatar
Id like to see one of your 25g logs. Wait....
Old Jul 4, 2013 | 10:16 AM
  #177
kdub1492's Avatar
Originally Posted by Fastgti69
I'd like to see some ZFR logs too . One I'd really like to see id kdubs wr3 logs.
If my fiance can find her computer that was lost/stolen I will log some and post. I have a Mac and use her HP to log/tune, she can't find her computer so I am SOL haha
Old Jul 4, 2013 | 10:22 AM
  #178
c130aviator's Avatar
i bought an 800 dollar dell laptop from a pawn shop for 300. Its my hpt laptop now.
Old Jul 4, 2013 | 11:15 AM
  #179
Fastgti69's Avatar
Soon, I hope. I finally hit 23 psi at 5.5k rpm after siliconing the leak etc. Now I'm guessing it's still the wastegate that needs a little more tightening. Saturday ima tighten it one more time. If nothing helps then I don't really even know anymore.
No worries man, get another log! LOL jk
Yep, bought a new laptop from bestbuy for 400 last year.
Old Jul 4, 2013 | 12:29 PM
  #180
kdub1492's Avatar
If she doesn't find hers then I'm just gonna wait until Black Friday this year and pick up a little NetBook for cheap. Dave is doing some tweaking to my car this Saturday cuz the 4" intake is a PITA haha. Gotta scale the MAF some and drop the boost a little. Really wish I would have just went with the 5th injector while the car was there oh well tho!
Old Jul 4, 2013 | 01:10 PM
  #181
You can run windows on your mac so you can still use hpt
Fastgti69 your issue has to be the wg. That kinu billet has given every evo owner problems. There is a guy im friends with on fb and evom that lives in savannah that has your exact version of the turbo iirc. Tom stout. He has posted his graphs. You should be spooling sooner.
On a side note i talked to a cobalt owner on fb last night who has recently installed a s20g and says he is getting 25psi at 3500
Old Jul 4, 2013 | 01:29 PM
  #182
I used to think my turbo comes on at 3500-3600 back when I had a boost leak. Then I fixed it.
Old Jul 4, 2013 | 01:45 PM
  #183
Wouldnt it spool later with a boost leak?
Old Jul 4, 2013 | 01:48 PM
  #184
it didnt on mine, the turbo would spool crazy fast when its not building boost and just tossing it out the hole in my manifold. At least that is my explination for my 3600rpm logs. I dont need logs now. I can sit in the car WOT it getting on the highway and watch the car build boost and almost by design it hits 4K on the tach and the car takes off like a rocket to 7K, I have to almost instantly shift.
Old Jul 4, 2013 | 01:51 PM
  #185
kdub1492's Avatar
Yea I've heard about using windows on my Mac, I'm just not sure on how to do it lol
Old Jul 4, 2013 | 02:02 PM
  #186
SSlobalt's Avatar
I bought a used Dell for $150 that was perfectly capable of running HPT. There are plenty of cheap, used laptops out there that will do that one thing you need. I leave it in my trunk because I don't use it for anything else.
Old Jul 5, 2013 | 01:39 AM
  #187
Fastgti69's Avatar
Craigslist is a good place for cheap laptops. BTW, I think James is going to come down to Cali. I'm going to buy his built motor and he's going to isntall the cams/valvsprings for me too and fix my 25g issue and tune it. So hopefully this will happen by august. It's worth the engine swap and to fix my issue and just go big. No i won't really have restraints on putting anywhere near 550whp+.
Old Jul 5, 2013 | 01:42 AM
  #188
Bad ass
Old Jul 9, 2013 | 12:46 AM
  #189
sujomatt's Avatar
I love my Super 20G! I recommend it when Hahn has 1 of their sales. Great buy
Old Jul 9, 2013 | 12:48 AM
  #190
thanks sujo, good to hear. The car is so dialed in right now, I love my car all over again.
Old Jul 13, 2013 | 08:50 AM
  #191
hucks1987's Avatar
C130, how much booste are you pushing???
Old Jul 13, 2013 | 04:41 PM
  #192
AARON-SS-TC's Avatar
1 million pounds....lol
Old Aug 11, 2013 | 02:43 PM
  #193
N1ckateen's Avatar
hey c130. I bought James' turbo setup with the custom built s20g. so far dyno wise I was extremely disappointed with the numbers I made only being 336 on 26 psi. 9* mid range 13* up top. I'm on stock motor and stock clutch so I know theres plenty of room for a lot more aggressive tuning. at least i'd like to believe there is. but I don't see how there can be that much room if i'm only making 336whp on 26 psi. when I run my buddy here in indy that's fully bolted with pistons and e47 on the stock k04 we literally have a dead even race. 60-135 mph we were less than a fender length ahead of one another. and he made 346whp/4xxwtq. at most i'd inch ahead of him throughout the rpms but when u counter in the split second of lag from 3rd to 4th we end up even in the end.
Old Aug 11, 2013 | 03:20 PM
  #194
Shortbus's Avatar
Maybe I won't be considering a 20g then, that's very disappointing.
Old Aug 11, 2013 | 04:10 PM
  #195
N1ckateen's Avatar
I wouldn't let my experience thus far effect your selection. i'm on a very weak tune just a lot of boost. very little timing and very slow boost ramp. I just think my numbers were a bit on the low side. but at the same time I don't have a true intake. i'm running just a 4" filter directly on the inlet so on the dyno my intake tempuratures were in the 130* range. so I know for sure that had a big effect on my results. out on the street i'm usually 3-7* within ambient temperature.
Old Aug 11, 2013 | 04:18 PM
  #196
Shortbus's Avatar
Ok, that explains a lot. I would like to see your dyno with a better tune and intake in some e47.
Old Aug 11, 2013 | 10:37 PM
  #197
you are not going to get the 20g over 400whp without ethanol or some form of it. The thing is you all are direct injected. Unless you run a 5th injector or a port fueler you are limited. I am on an LSJ with big injectors. SFI and e85 on 27lbs of boost and 19 degrees up top made the 472 wheel horsepower. Full mods list in my profile garage.
Nickateen keep working on it your numbers can get a lot better than that.
Old Aug 11, 2013 | 11:20 PM
  #198
472whp is nasty...would love to have that
Old Aug 12, 2013 | 12:26 AM
  #199
I think we all would.
Old Aug 12, 2013 | 05:48 AM
  #200
hucks1987's Avatar
Brandon K hit 435 on 93.
